The Cobalt DTC thread (merged)
On Saturday I was coming back on the interstate and all of a sudden my check engine light came on, i had noticed that my car was running a little sluggish a when i first started....i took it to the dealer b/c it is still under waranty and they said I need a new fuel injectore....odd if you ask me, the car is only and 06.
Modified Exhaust now CEL's - P0030, P0036, P0102, P0443 - Solution Inside
So i traded my GM performance exhaust for a friend's DC sports exhaust just for the hell of it. i dont regret trading, although i had some problems...
first, the bolts wouldnt screw in right so i had a hell of an exhaust leak (took it to the muffler shop and they fixed it) .. then my buddy put the o2 in wrong and the wires were pressed up against the heat shield. the mechanic at the shop told me the wires on the o2 had been split causing me to throw 4 cel's... so i left.. driving on down the road the car begins to run like complete **** (had been doing this since i first put on the DC Sports) .. would deleting the rear o2 make me run correctly again?? tomorrow i was supposed to get my rear o2 deleted anyway for the p0420 code so i can pass inspection. do you think by me deleting the rear o2 these codes and problems will go away?? Thanks!!!
codes are as follows...
P0030 HO2S Heater Control Circuit Sensor 1 ECM, PCM
P0036 HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency ECM, PCM
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit ECM, PCM
P.S. tried to remove them with my interceptor and they just keep coming back...
*shakes head*
why oh why do you get yourself into these things my friend?
you know there's a whole crew of us right down here in Charlotte with HPTuners that will be glad to fix you up.
I had the same thing happen to me when I put my hahn cat back on. Check your ems fuse under the hood(10amp).If it's poped you have a straight to ground short on youf o2 sensor. Look for bare wire then tape it up.My would do it when I made a right hand turn and the exaust would swing left an touch the heat shield and pop a fuse. Good luck
problem fixed, your welcome
unfortunatley HPT won't fix a wire shorted to ground
Huge thanks to Sunburst_SS for pin pointing the problem!
Original Hayden Fanatic
!!!I LOVE YOU ALL!!!
Ive been throwing those codes for 2 months without a solution, i was ready to buy new o2 sensors because of it!!
I've searched and never read this sollution!!
#36
if you have a manual transmission....there was a bullitin for wires rubbing on the clutch pedal assembly, and by the oil filter housing. It'll cause an intermittent code, might want to check that out
#37
here's what SI says about the blown/loose emissions fuse.......just something to check if you're having those codes thrown
There are 2 main areas to look at for the cause of this blown/loose fuse.
Check circuit 5291 for a short to ground (STG) at the clutch pedal position switch connector as it might get shorted to the clutch bracket. If connector looks ok, then inspect the 10 amp emissions fuse in the Underhood Electrical Center to ensure it is properly seated.
Note: This clutch position switch connector is there even on automatic vehicles.
Check for a short To ground (STG) at the oil filter adapter housing.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
basically a p0833 will set when the ECM senses a certain number of gear changes without
detecting a clutch switch movement.
#39
Nice, I stickied this, I think the issue might be the design of the older ZZP midlengths putting the o2 sensor to close the the wall, and when the engine shifts during driving it can cause it to rub. As I have/had the same issue going to a shop and having the o2 sensor rub as the OP mentioned.
#41
#42
Check for a short To ground at the oil filter adapter housing.
maybe you're getting an intermittent short on the circuit.....check that out
#48
South Central *********
checked for shorts for ground and checked the clutch harnesses
rerouted and secure all the connectors and harnesses by the oil filter with zip ties
any other thoughts?
Have never popped the emiss fuse but on my scanner it show the O2S1 heater dropin for 0.6A to zero amps intermittantly
any other thoughts?
#49
any other thoughts?
any other thoughts?
