Codes, Codes, Codes!
Old 05-30-2010 | 08:38 PM
Chad92's Avatar
Hey folks, long time no post. Glad to be back. =)
Driving home from work today, my CEL came on about two minutes after I started the car. I was doing about 50 km/hr and was approaching a four way stop. Cloudy and muggy, since it has been raining/snowing for the last few days. Got home and pulled my CarChip and checked the codes:
P0104 - Mass or Volume Air Flow Circuit Intermittent
P0003 - Fuel Volume Regulator Control Circuit Low
P0400 - Exhaust Gas Recirculation Flow Malfunction
P0765 - Shift Solenoid D Malfunction
C0665 - Chassis Pitch Signal Circuit
C0600 - ???
I have a trip log showing what time the codes were thrown at and what speed, engine speed, etc at the time if that helps. Is there anything I can do to remedy it myself? Is it safe to just reset the CEL? What should I look at before thinking about taking it to the dealer? Just over 63 000 km so no more bumper to bumper warranty but I still have my power train and emissions.
Thanks!
Old 05-30-2010 | 08:41 PM
outtamymind's Avatar
clear all dtc's and see if they come on again, sounds like a little bit of a glitch on the sensors.
Old 05-30-2010 | 09:52 PM
ryaan's Avatar
"ive got hoes... in different area CODES, area CODES, area CODES" - ludacris
Old 05-31-2010 | 12:08 AM
Chad92's Avatar
hahaha
Thanks Steve! Hope everything is well with you!
Old 05-31-2010 | 01:56 AM
Originally Posted by Chad92
hahaha
np, and they will be eventually. i'm hoping to come up that way a few times this summer for some fun at castrol
Old 05-31-2010 | 01:33 PM
Coblasts's Avatar
Check to make sure your Emiss fuse or pwer train relay are not loose.
Under the hood fuse box.
Also check the box for water intrusion,if its wet inside put the hair dryer to it.
Old 06-01-2010 | 12:30 AM
Chad92's Avatar
Checked that today, pulled some fuses and checked them out, all good. I'm thinking the car just had a seizure.
Really?? Let me know when you're coming up I'll join ya!
turbochargedss2012
09-20-2023 01:17 PM
ernnyyes
10-02-2015 06:16 PM
Extremespeed
09-29-2015 05:34 AM
DocSvensk
09-27-2015 03:24 PM
OrangeCoba
09-25-2015 07:06 PM
