confused and dead ended
Maybe someone here can help, I am having intermitten surging under low rpm low load, also high rpm stuttering. Had the MIL come on once Pulled a code for Bank One lean condition, replaced fuel filter, still haveing problem, checked fuel pressure, good, cleaned TB, cleaned MAF, checked plugs GAP .033, Put scope to injectors while running sound fine, maybe there is something simple i am missing?
EDIT: MODS; Catch can, CAI
How many miles are on it? I pulled my buddies fuel rail off his SS/SC because he had a high rpm stutter and low rpm surging . Turns out the rail was full of **** along with the injectors....it was so bad you wouldn't believe it . We cleaned it all out and then started the car .....and it fill up with another slug of crap........so then we cleaned it all out AND flushed the fuel line .......a huge amout of rusty **** came out of the fuel line.....truely unreal .
He had 40k and had only used 93 from decent stations. Had already done his 2nd fuel filter. I still have the **** that came out of the rail in a old gas can I just gotta remember to take a pic .
I was amazed that the car ran as good as it did with the amount of crap in the fuel system.
z28addiction
09-28-2015 12:03 AM
