Coolant Temp Bouncing
I have an 06 ss\sc just installed OTTP H\E i just want to double check i installed correctly. So the top hose goes hooked up with the out hose of the stock h\e and the bottom hose goes hooked up with the top or in of the ic pump correct? I dont have a dual pass yet or option b. I'm just wondering cause i've been driving around today watch my coolant temp bounce around. Usually it stays around 183 or so today it was going over that. also whats the correct way to flush and fill the whole system? Any help would be greatlly appreciated thanks in advance.
It's probably just an airflow issue. Your new H/E is now blocking flow to your radiator. This is why the most efficient recommendation is to replace the stock H/E with a griffin unit...
I needed soemthing to plug the drain hole in OTTP's H/E so I got an adaptor and pluged it with a fluid temp sensor that I ran to my Analogic Gauge
I Love my gauges
thanks for the in input guys really appreciated. So it bounces pretty good today i went to work which is mostly highway so it stayed at about 178 to 180 pretty steady then after i got off the freeway it started to go up to like 196 around there. When driving it would go doen a bit but not much. Also whats the correct way to flush and fill system? Thanks to all of your help very much appreciated.
Also remember your engine is working harder to keep you at cruise then it is idleing at a stoplight....
BUT.. you have more airflow at cruise so your temps will be lower, when you stop, your temp well go up since you just lost your cooling air, Once temps reach a cetin point determined by your tuen (I think 223 to 230 degrees) your fans will start to come on, slow at first then faster giveing you back your cooling air.
custom one is meh. flow through is only going to be considered to be advantageous over opt b in the fact that you can put ice in it if you're at the track. at that point you're grasping at air though imo. the one pictured doesn't bleed air either.
