coolant temp sensor
coolant temp sensor
08 2.2 Supercharged... Coolant temp sensor went out this morning. Second time in 3 weeks... Anyone have any possible idea why? Or just bad replacement part you think?
well since nobody responded, i'm going to ask once more since there's more than this which is an issue right now... throwing p0116 and p0328... i know what the codes are but i'm not sure if they're wiring problems or if they're the individual part problem.. insight would be awesome. thanks
you need a scan tool to see parameters of ect then compare it to the intake air temperature sensor, the IAT sensor 2 should be close 16F of each other and disconnect ect and test resistance between terminal A and ground should be less the 5 ohms if more def wire issue or ecm and if thats ok sensor is f'd .your knock sensor could be shorted to ground or power intermittently hope this helps out!!
