Coupe door rubbing?
Coupe door rubbing?
Anyone getting this problem? It seems my door is improperly fitted, so if there's any dirt or anything on it when I open it, the bottom rubs against the frame... Think right down on the bottom of the door, closest to the engine.
I kept hearing a grinding when I opened the door and brushed it off, until I looked closer and saw a 1.5" long strip with no paint; right down to the metal.
I'm taking the thing in to the dealer to see what they can do... I have no idea if they can re-align the door.
Once again, thank you to the UAW for a wonderfully built car Little things like this aren't enough to make me regret my purchase, but this kind of bullshit is frustrating none the less.
Anyone else have this issue?
I have the same issue with my 06 SS/SC? Piant is rubbed of in the exact same spot and creeks when opening and closing. They better fix this when I bring it in!!!
you better still have a warranty on it or they arnt even going to look your way unless its comin out of your pocket.
my 08ls had the driver's side door misaligned too when i got it, but mine wouldnt close cause the lock would not latch without me closing the door very hard. i took it in and they looked at it and said that they fixed it, worked for 2 days and it happened again...took back in and they fixed it...but it's not as good as i want it. that's what we get by not spending 30G on a car.
i dont think you need to spend 30 grand on a car for the damn doors not to rub, this is something you expect from a chinese auto maker, not 100grand a year employees!
both doors on mine 08 were not properly installed dealer gave me hassles and said it was fine so I went to thier bodyshop who told me the were both aligned wrong then shut up when I mention the dealership so i went to the next dealership fixed no questons asked
we do those at my dealership, they grab 3 guys and push the door up so you don't have to loosen the bolts...i still don't know how i feel about that though....
