crankshaft position sensor
i get a p0300 all the time. random misfire i'm assuming is that. when i was tuning it, most of the time at idle it just stopped reading rpms, went from 800 - 0 with no in between. car likes to lobe at idle. i've kinda had the problem since before the car blew, so that's the problem i've been assuming. i also can't go into more than a couple pounds of boost and i can't tell if that's the tune or the sensor but i'm still in my break in period
i have a P0300 always showin to. and yes it is a random misfire. you have any idea what causes that? other than the P0336 code, my car runs just fine. i get full boost and everything with no problems until this code showed up the other day after it wouldnt go past 3,000 rpm's
not tring to bring a dead thread back up. but i did mine today, can do it without taking anything off if you have small hands and take your time. havent popped a code up today and ran much better. we will see
