Crankshaft Position Sensor replacement w/HPT
Does anybody here know if using HPT to complete a case relearn after replacing ckp sensor requires unlocking my vehicle first? or does HPT allow "generic" services like that without unlocking to a car/vin first?
I appreciate that. I'm gonna try to get in there after work today and see if i can avoid the relearn. it was running somewhat decently yesterday not getting into throttle, but it's ass today.
If you have any other potential ideas, i'm all ears as to what to look into though.
I was thinking about that, but the only person in our local group i know of, i don't know that i can get that far with my car once the sensor is replaced if it's still running like **** (won't start at all now). I'm replacing it this afternoon and am going to go from there. man, this is lame lol.
I can clear the code and limp to a local garage that's gonna relearn it for me, so i appreciate the knowledge.
That said, getting to the sensor from the top, without removing the starter (because my car died and is on an incline so not willing to lift it) is a BITCH. got it out, and then found that the buttface at O'reillys gave me a camshaft sensor instead. so it should get done today. bit ridiculous for something fairly simple, but it is what it is.
it was awkward, but got it done. Didn't get my anywhere though. throughout the 4 days it was down with no part, i pulled terminals occasionally as i was working on the front end. re-connected everytime i was done working. last night the security and check engine light were clicking/flashing crazy fast and it wouldn't crank, now it won't even show the mileage when i open the door.
My battery is dead enough that a 10 minute charge didn't help, after just a few days of non-use.
hahaha... news of the day being that it isn't just tbe sensor. found that out after a few hours of shop guys not being able to get it started. guide snapped too. no warning signs that i'm aware of or noticed. timing deluxe kit here i come.
That's crappy. But you have good spirits about it, so way to be man!
Just hoping it's the kit is all that's needed, and i get to learn from it, so i'm good. same with the crank sensor.
I can't be mad that i didn't replace something in a timely manner, not that i knew it was this far bad. I'm just hoping there are no issues with valves. I won't be able to get the car away from the shop to check it out until at least Monday, so we'll see.
Replaced all the timing components, but the bitch guide bolt sheared off. drilled it out, found half the guide fell into the oil pan. now i'm dropping the oil pan to pull the piece of guide and reseal the pan.
Last BITCH of a problem, is that the crank gear key mushroomed a tiny bit trying to put it back in, and nowhere sells it. Dealer has to get it shipped in. If i'm lucky i'll get to drive it Friday.
lol, tried that, tried a file, i think when my dad got in there he just got a bit excited trying to get that in since it was close to the end and hit it harder than wanted.
At least when this stuff is done i'll have springs, bushings, rack spacers, and the tablet to throw in there to make me not want to burn it to the ground lol.
Bandit2941
01-12-2017 08:06 AM
Jay P.
02-23-2016 12:45 AM
