CylindLer Misfire CEL
P0300 - Engine Misfire Detected
and I also got
P0171 - Fuel Trim System Lean Bank 1
I read about the P0171 and how it could be so many things that cause it. I have double checked every part of the intake. Everything is tight and secure. My EVAP hose on the TB was kinda pinched so that might be why I got the P0171 also my exhaust sounds a bit funny so I am thinking there is a leak when I installed my LSJ Exhaust Mani and DP.
I am a 2005 SC'ed 2.2L. Everything seems to be running good except my boost gauge isn't picking up a reading.
What can cause the P0300? Bad plug? Wrong gap on the plug?
Also yes I realize "cylinder" is typo'ed in the title.
and I also got
I had p300 as well 'random misfire' and p0172, both of which are caused by aftermarket intake. I would clear it, but would come back later. Zach tuned my car and also fixed this problem as well.
I noticed that the Aeroforce Interceptors at least on my car, some how create phantom misfires. The engine doesnt seem to misfire, yet it counts misfires, and throws erronious P0300 codes. Normaly this only occurs if you set your interceptor to watch misfires. I can check my codes with my interceptor and I get P0300 and I check with my scaner I baught at Advanced Auto Parts and I get PASS No Codes.
Also,
If I idle for 15 minutes while watching misfires, I get a engine light.
If I idle for 15 minutes while watching some other paramater nothing
happens.
I unplug interceptors
No misfire codes..
Just keep in mind.
-Jonathan
Sean Cummings
03-09-2018 12:26 AM
Getaway_Driver
09-08-2015 09:41 AM
