Dealer B.S.
Dealer B.S.
So I took my car in to be serviced because it is making a loud roar when I accelerate and only when I accelerate. It kind of sounds like a go-kart when I accelerate and it was really pissing me off. Another thing was that my ABS and Traction lights would come on intermittently after I would be driving for awhile. So I drop my car off suggesting that there is an exhaust leak, and I had no idea about me ABS and Traction besides maybe when I put new rotors and pads on I messed something up. The guy says he'll take a look at it and when he calls me back the next day, he states that my B&M Shiftplus is causing both problems. Right away he states that he could charge me for the diagnostics since its an aftermarket part and it voids my warranty. I told him that was bullshit and that the only way to void the warranty is to prove that its that part.
HERES THE REAL ISSUE AND QUESTION I HAVE: To that he answers that the computer in the car reads every shift and mis-shift of the car, it reads the pressure of the transmission fluid that is pushed through when shifting, and that he could even figure out how fast I was going if he analyzed some of the information in depth. SO the question is, does the car really have that much memory and can it determine if a B&M shiftplus is present if I were to take it off before I took the car in for service.
My car still makes the noise, and I'm waiting for the lights to come back on but they havent yet. I want to take it back in to a different dealer so he doesnt try to screw me.
Please fill me in if they can read all of this information off the car, if he is actually being truthful and not just trying to bullshit me into trying to pay. He didnt charge me because he wants a good survey, which they arent getting because they didnt fix anything.
Thanks.
Thanks.
Even better today I was driving and both the ABS light and Traction light came on, and the engine or exhaust is still making noise and the shift plus is off.
I really dont know why peaple mess with their cars.And get pissed at the dealer when its not covered.When its screwed up from your own doing .I couldent understand that ????
It not my fault.....hence what I am saying the shift plus has nothing to do with anything that is wrong because it is disconnected and everytihng is still happening even after the dealer reset the codes on the computer. SO basically I am proving the dealer wrong with him blaming it all on the shiftplus which is bullshit
You dont understand because you dont know anything. The B&M Shift plus is NOT the cause of his problems.
If you change the way your engine or transmission functions...EVERY related part is affected
GM WILL and CAN void your entire warranty for having a shiftplus. Harder shifts = more stress on trans = more stress on engine = more stress on exhaust
If you're going faster, you need to break harder (brakes are void), and your suspension will be affected (suspension is void)
Don't mod your car and then bitch at the dealers, try going to a different dealer and see if they'll look at it
funny because when installing this you do have to splice into the trans wires, assuming you did cut the right ones, they might not be making good contact. try dc'ing the battery to reset the ecu overnight
when i installed my shiftplus, the instructions on page 1 were not for 07's, and i cut the wrong wire, which made my trans go into a limp mode: wouldnt shift out of 1st, TC and ABS on
Oh ****! My bad.
The only thing with that is that the tranny is rated for much higher than the pressure that is put through it stock. So there for there should be no problem. Also when I told the dealer that I had had it on for over a year and that I had never had problems with anything, he had nothing to say to that because he had assumed it had happened since I had it on, when really it has only started up in the last week or so
your suggesting that an otherwise stock car cant handle a B&M shiftplus transmission wise?
and Moss Magnuson says that unless they can prove it they cant void your warranty
btw, with your logic an exhaust voids the entire car as well.
Exhausts are louder then normal and cause different vibrations in the engine compartment plus they generally give you a horsepower increase so the brake and suspension things would be the same.
but try and ******* prove that exhaust can do that and ill laugh in your face
the issue *might* not be related to your shiftplus, but it sounds like it could be
i would make sure the trans wires you spliced/cut are still in tact and making good contact
there is a Trans flash for Autos, I just had it done on my 07 LT auto. if he's not willing to help, try taking it to another dealer and see what they can do
don't forget, those 'service advisors' are salesmen and often work on commission/performance based pay, they are not there to help you with warranty work, they're always trying to sell you on something
aftermarket parts that effect your drivetrain, can void your entire drivetrain warranty (engine, exhaust, manifolds, trans, shifters, gaugues, etc)
go ask your dealer if you install a catback exhaust if they'll void your warranty
edit:
I wasn't saying a cobalt auto trans cannot handle a shiftplus, i know they can b/c i have one...been running over 2yrs with it
i see it happen every single day buddy, the chevy dealer here in town that is #2 in the country. they void warrantys left and right and GM approves of it.
edit:
edit:
to a certain extent i also believe some people should STFU about warranty issues especially with intakes and what not, if you have the money to fix it, feel free to modify. if not dont **** w/ your car
agentirons
10-16-2015 02:11 AM
