diagnostics came back, need your help!
Old 08-26-2010 | 01:44 AM
4dr-RS's Avatar
well the diagnostics came back for my car and it reads as so:
*replace O2 sensor (bank 1 sensor1)
*coolant getting stuck to sensor
*replace thermostat
*change coolant
shop wants $300 for all that and labor so...**** that! im gonna do it myself. i know the O2 sensor is like $70 but how do i replace it? also how much is the thermostat, how do i replace it, and where can i get it and one more thing, which coolant do you recommend i get and how much is it?
thanx
is there a how to: to any of these issues?
Old 08-26-2010 | 10:08 AM
insylem's Avatar
I hear the theromostatd on these is a bitch to change not sure where it's at.
The O2 Sensor is on your exhaust manifold. I think its best to get to it from underneath, YOu'll need an open end wrench or a special cut open deepwell socket for an O2 sensor for the wires. Simply twist out the old one, disconect it, and slap a new one in.
Changeing your coolant and Thermstadt can go together
Just drain allthe coolant out, swap out the thermo when
your coolant is empty and fill it back up.
Old 08-26-2010 | 12:26 PM
4dr-RS's Avatar
alright sweet o n its not the sensor on the exhaust mani, its the one on the downpipe before the cat cuz i dont have an O2 sensor on the exhaust mani.
o i also heard that its a MUST to get the ac delco o2 sensor
Old 08-26-2010 | 12:31 PM
1RS1SS's Avatar
*replace thermostat
*change coolant
thanx
This type of works sucks to do on a 4 banger.
Old 08-26-2010 | 12:32 PM
rnjmur's Avatar
Use dexcool when you put new coolant in.
The thermostat is in a housing just behind the water pump. It is on the back side of the motor, passenger side, under the exhaust manifold.
Old 08-26-2010 | 12:35 PM
4dr-RS's Avatar
i bet! i bet im gonna end up busting my hand trying to get that O2 sensor out
hmm alright how do you remove it though?
Old 08-26-2010 | 12:42 PM
PRND3L's Avatar
Sub'd for Lawz.
waiting for the following threads:
"o2 sensor broke off in exhaust"
"broken T-Stat Housing, what did i do?!"
"How to turn a 300 dollar repair into a 2000 dollar repair"\
IF YOU DONT HAVE A CLUE, DONT ATTEMPT IT!!!!!!!
Old 08-26-2010 | 01:23 PM
4dr-RS's Avatar
Originally Posted by PRND3L
Sub'd for Lawz.
is it really that hard?
Old 08-26-2010 | 04:22 PM
rnjmur's Avatar
I have never done it, so not for sure. I think you take the metal coolant line and housing off, maybe a couple of bolts, then you can get to the thermostat. I think the biggest problem is getting to the bolts because the exhaust manifold is right there. There a couple of guys who have changed their thermostats and should be able to give you a better how-to. You might try posting a new thread called "Need help swapping my thermostat" and see if one of them can help you out.
Old 08-26-2010 | 07:57 PM
4dr-RS's Avatar
hmm alright thanx
Old 08-26-2010 | 08:02 PM
DarkCobalt13's Avatar
problem is the placement of the thermostat housing makes it a PITA..... If you have a 5spd trans, that will help because the trans wont be in the way
Old 08-26-2010 | 08:13 PM
4dr-RS's Avatar
great thats another reason why i hate my auto tranny
Old 08-26-2010 | 08:31 PM
army_greywolf's Avatar
Let me give you some advice based on the input thus far. Take it back to the shop and let them do it, after all if THEY screw it up it's on them, if you screw it up (and there are bolts that go into aluminum, plastic housing.
I'm a tech, I can tell you 7/10 times a customer comes in for a diagnosis and the repair isn't cookie cutter easy, if they leave after the diag, they always bring it back with a broke part or it comes back on a wrecker, also broke, only now the labor includes R&R plus the repair of broken studs, and additional parts for missing bolts, nuts, repairing broken wires or the dreaded, it didn't run rough and have a check engine light before but now it does, please help!
If all else fails bribe a knowledgeable friend with the appropriate brew to at least supervise your attempt.
Old 08-26-2010 | 08:54 PM
On almost any other car, I'd say do your own damn thermostat but these Ecotecs are not easy..... as for the O2, those are not easy without the proper tools because of the rust buildup down there.
Just take it to the shop that diagnosed it
Old 08-26-2010 | 10:59 PM
4dr-RS's Avatar
alright well i'll keep u guys updated on what happens, im taking it to my dads friends shop and im gonna see how much he wants to charge me
hacadacalopolis
10-28-2015 07:09 PM
10-20-2015 10:56 PM
dennis69
10-20-2015 05:49 PM
Trav3480
10-01-2015 09:17 PM
DocSvensk
09-27-2015 03:24 PM
