Dipstick Popping Out
Old 12-15-2008, 06:09 AM
  #76
Raven SS's Avatar
those numbers seem real low steve...i posted this a long ass time ago but the mods didnt feel it needed to be stickied...how wrong were they? https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/leak-down-test-informational-thread-93210/
Old 12-15-2008, 11:18 AM
  #77
Steven Flit's Avatar
Originally Posted by stryder
eh thats ok, you would like it to be closer to 200. have you done a leakdown test?
been modding and running it hard since it hit 10,000 miles. The car is now at 42,000k now
Originally Posted by Raven SS
those numbers seem real low steve...i posted this a long ass time ago but the mods didnt feel it needed to be stickied...how wrong were they? https://www.cobaltss.net/forums/showthread.php?t=93210
Just the usual wear n tear I suppose...
Thanks for the link
Old 12-15-2008, 01:52 PM
  #78
Fail Less.
Bika's Avatar
click. going to do this soon.
Old 12-16-2008, 11:51 AM
  #79
new intake manifold gasket arriving Friday...
and update to come this wkd.
Old 12-16-2008, 11:54 AM
  #80
Haz l33t wheelz.
ls1fbody's Avatar
sweet. lets cross our fingers thats it. Or, now you have an excuse to build the motor.
Old 12-16-2008, 12:06 PM
  #81
Supercharged06's Avatar
i know it was posted a few days ago but are you guys sure its 6.5 quarts of oil bc im reading my owners manual and it only say 6 quarts, which is all iv ever put in mobli 1 or royal purple every time
either way i dont think 1/2 quart is gonna kill anything. im just wondering were you guys got that from
Old 12-16-2008, 12:26 PM
  #82
nuttzzy's Avatar
I Always poured the oil in till it said normal on thed dip stick and was always 6.5 quarts
Old 12-16-2008, 03:28 PM
  #83
blackbird's Avatar
It's just a guideline. Drain the old oil and reinstall the drain bolt, install the new filter and then put the car back down on level ground and add oil until the dipstick reads full. Then start the car, let it run for a minute, shut it off and re-check the level after a few minutes (giving it time to drain back to the pan from the top end), topping it off as needed. I'd never just drain and refill with a specific amount. Overfilling can be worse than running a little low since it can cause aeration of the oil and potentially seal leaks on certain engines.
Old 12-16-2008, 06:12 PM
  #84
I dont wanna build the motor anytime soon
lol... but yes.. a good excuse
Old 12-19-2008, 10:18 PM
  #85
Got the new intake manifold gasket today.
any advise on if the numbers on it face you or away from you?
the side w/ numbers has what looks like rings around the holes that protrude outward. On the otherside of the gasket the rings around the holes go inward.
Old 12-20-2008, 01:08 AM
  #86
Rent me! per hour
Area47's Avatar
line up the gasket with the holes in the center of the head. the pcv gasket hole and such
Old 12-20-2008, 01:26 AM
  #87
ill give you an update tomorrow
Old 12-20-2008, 01:33 AM
  #88
Codyak Supercharged's Avatar
hope it works man
Old 12-20-2008, 01:44 AM
  #89
Originally Posted by Codyak Supercharged
hope it works man
can't possibly be anything else...
should fix it
thanks for the positive note though
Old 12-21-2008, 06:08 AM
  #90
project extended until 12/21/08 after 5 p.m. p.s.t
intake manifold gasket re-installation
update to come in 15-17 hours...
Old 12-21-2008, 06:23 AM
  #91
Haz l33t wheelz.
ls1fbody's Avatar
i twiddle my thumbs in anticipation. Hope this works for you steve.
Old 12-21-2008, 10:38 AM
  #92
thedubsack85's Avatar
damn work.. dont get off work till 5pm.. and im late going there cause of more problem's... YAY... see ya at 5 man.
Old 12-22-2008, 12:20 AM
  #93
changed the intake manifold gasket
unfortunately ive yet run into another problem
Old 12-22-2008, 12:59 AM
  #94
that sucks
Old 12-22-2008, 01:12 AM
  #95
The new gasket thats installed has what looks like little imprinted lines around the rectangular holes.. I'm sure there are those of you out there that know the actual term...
THE OLD INTAKE MANIFOLD GASKET
Old 12-22-2008, 01:38 AM
  #96
WSFrazier's Avatar
Lol, am I flying to Cali for the third time? Would be nice to see you and Shaun again.
Old 12-22-2008, 02:24 AM
  #97
haha not anymore!
I figured out the culprit and it wasn'the intake manifold gasket!
my car has all three upgradable solid mounts
well the dipstick comes connected to the oil pan and then fastened to the intake manifold. I undid the bolt that fastens it to the intake manifold. PROBLEM SOLVED!
The car vibed so much it made the dipstick inside rattle and turn its way upward.
thanks for everyone who helped me...
I'm still leaking a smidge of oil thru the valve cover gasket in one area, and a new gasket will be ordered soon for that.
it's not excessive crank case pressure; because i took off the oil cap and put a rag over so nothing spills out, and it still popped the dipstick. only when i undid the dipstick bolt connecting it to the intake mani, did it not rattle itself loose.
AS FOR NOW, MY NEXT HURDLE WILL BE TO LEARN MY HPT AND MAKE A 13 SEC PASS!
Old 12-22-2008, 02:26 AM
  #98
bryce712's Avatar
glad to hear that you got this fixed man
Old 12-22-2008, 02:42 AM
  #99
FZWCobalt_09's Avatar
It pops because of crank case pressure. umm dsmers always just crimp the metal pipe whre the dipstick goes in around the dip stick. so thats all i know to do. lol.
Edit... atta boy..
Old 12-22-2008, 03:05 AM
  #100
thanks, appreciate it
Edit... atta boy..
ATTA BOY IS RIGHT!!! damn I suck at working on cars! lol... I try and fix one thing and break another haha
Now its time to fix that leaky valve cover gasket before track day on Jan 10th. Bah...
Went logging
in 3rd @ 89 mph, 5597 rpm, 11.6-11.8 ACTUAL AFR: 97* IAT2, 48* IAT1, 0 knock, 63% IDC, 206 Kpa = 15.1 PSI, and a craptastic 13.5* of timing! - This is with the meth off, just 2.7, 3" header back exhaust to a stock muffler, ported blower, CAI, option b w/ dual pass, and cobra H/E
Now its off to the body shop to get plastic surgery thanks to a 78 yr old man who hit my car while it was parked... errr
Once I get it back, I'll mess w/ the tune.
Quick Reply: Dipstick Popping Out
