Drive by wire problem?
im having problems with driving, no check engine light (2006 SS/SC) its like going from 1000 RPM to 2000 RPM and it makes no differentce if i hit the gas or not. but it only did that twice last night? anyone had this problem?
i failed to mention the dealership removed and placed my supercharger back on... when ihit the gas its like the computer dosen read im pressing the pedal
i cleaned my mass pressur sensor, did nothing, i checked my throttle body looks brand new and works like its supposed to... again it boggles, it drives like im playing bass drum with the gas pedal. im puzzled and irritate as there is always something wrong with this ******* car.
That apparantly can throw the MAF out of whack a bit from what I've read. Do you still have your stock intake? If you do I'd try putting it on and seeing what happens, it doesn't cost you anything and would rule out the intake.
Joel
Joel
Little update: yesterday i took my light off and the light bracket giving me acces to everything and indeed my filter has accumulated an amount of ice and my MAF i cleaned it and wow like a brand new car!
the problem was that the ice accumulates in the fender wells and when you turn your wheel it unclips the wheel wells and leaves your filter vulnerable to everything on the road.
