Drivers door lock
Old 07-15-2015 | 11:10 PM
AllicatR84's Avatar
Drivers door lock
I have a 2007 SS non turbo sedan that been having this problems the past month with my drivers door. It wont unlock with the key fob or driver/passager door switchs. It jiggles like it want to, but doesnt fully unlock. I can manually unlock the door by puller up the switch on the door and the door opens fine.
Old 07-16-2015 | 10:09 AM
sc4door's Avatar
Might just need lubricated. Pull the interior door panel off and get some white lithium grease and spray on the mechanism while you lock and unlock it. If that doesn't work, the actuator is probably bad
Old 07-16-2015 | 10:19 AM
Kolt's Avatar
You need a door lock actuator.
Old 07-16-2015 | 05:09 PM
double clutch's Avatar
Drivers door lock
^both these guys are right. And if u let it go too long your door could get stuck on lock like mine did. I had to crawl in and out the passenger side for a week.
Solaris99
28
03-15-2017 02:22 PM
dennis69
10-20-2015 05:49 PM
agentirons
10-16-2015 03:11 AM
Extremespeed
09-29-2015 05:34 AM
Trav3480
09-28-2015 03:46 PM
