E-Brake handle fix
Old 10-05-2009 | 11:24 AM
cobaltcraz's Avatar
E-Brake handle fix
this is the 3rd time I have done this to my wifes car so I figured I would take pictures for anyone who needs help with it.
1st take the center console out of the car the whole thing. There are bolt you cant get to with it in.
Then take out off the mount for arm rest.
There are 4 bolts that hold the brake handle in place and you have to pull the cables out of the mount use a flat head screw driver to push the white tubes out of the back of the mount.
Ok by now you will need a few of these
This is the peice that fell out
If you can see it there is a place where it fits in to.
This is what it looks like with it in its place
you have to press the release button to get it to set in there then get a wide flat head screw driver to wedge it back in to place.
This time is set it in place with J-B Weld so I will see if it fixes it.
Old 10-05-2009 | 03:41 PM
NYG5GT's Avatar
Thanks a lot! This will be very helpful
patooyee
10-15-2015 06:11 PM
dieGone
10-01-2015 07:27 PM
Tupp
09-30-2015 09:18 PM
yellow dragon
09-28-2015 10:49 PM
SlowSaturn
09-28-2015 12:03 PM
