E-Brake wont work at all
i usually let my car warm up before i leave in the morning but today when i started it and was about to get out it started rolling back...so i pushed the brake in and pulled up on the ebrake as far as it would go and it still rolled back...
1. the brake light is still on
2. and ive noticed when driving a few weeks back the ebrake light will flash for a split second..
whats wrong??
Ttt.
whats wrong??
Ttt.
Last edited by CobaltVenomSS; 02-15-2010 at 02:06 PM. Reason: Automerged Doublepost
There are two cables, one for each rear caliper, that apply the brakes when the e-brake is pulled. The two cables attach to a H shaped piece under the e-brake handle which attaches to the handle itself. If the cable(s) stretch, or if the springs on the rear caliper(s) that attach to the e-brake cables stop working the e-brake cables can "slip out" of the H shaped piece. If that happens you will no longer have an e-brake. If the car is still under warranty then take it into the dealership and have them fix it.
If not under warranty then pop the plastic off from around the e-brake handle and check the cables. You maybe able to adjust the ebrake, but you also need to check if the rear calipers are bad otherwise you could cause more issues if you adjust them.
sorry i work at a dealership, some ppl just dont understand.
My parking brake is loose in the handle. I think it might be from just yankin on it a lil hard lol. mayb u should lay off the roids sir
cuz the stealership less than a mile from me well lets just say idk if there giving away free cars and happy ending with every visit will never see me again i now drive 30 miles to get my car worked on
