Engine code after header Dp
Ok I have searched all over the net and can't find a good solution. I put a Badmab header and zzp 2.5 catted dp on and now have a code 1133. The o2 's are 6 months onls and denso's not the cheaper ones. Anyway has anyone gotten rid of this code after a header and or dp install?.
Never got that code from messing with the header or exhaust. Like I mentioned to you, the Denso O2's are known for acting up in these cars. I'd pull it and inspect it, and or replace it with a factory NTK replacement.
Knowing Badmab and the cheap quality it is possible the O2 sensor bung was welded incorrectly causing the O2 to sit back to far causing false readings.
ItalianJoe1
05-19-2016 04:20 PM
Doug's Cobalt SS SC
05-15-2016 09:36 PM
medic710
05-15-2016 08:47 AM
