Engine coolant temp
Old 01-19-2018 | 06:27 PM
  #51
its oem temp and fitment but definitely not oem manufacturer
Old 01-19-2018 | 06:46 PM
  #52
jdbaugh1's Avatar
I've just always got what the local CarQuest or whatever flavor has and made sure it fit right with the right cracking temperature and never had a problem. Definitely didn't pay $40 for one. The ACDELCO 180F T-stat is on RockAuto for $15. 2006 CHEVROLET COBALT 2.0L L4 Supercharged Thermostat | RockAuto
Old 01-19-2018 | 06:57 PM
  #53
I just put a carquest one in my daily.... We'll see how that goes.
Old 01-19-2018 | 07:24 PM
  #54
Doug's Cobalt SS SC's Avatar
Thanks JB I'm on rock auto right now picking up the ACDelco one. Question do I need one of the $3.39 ACDelco seals under thermostat housing water outlet seal ? Or I'm I good just with the TSAT itself ?
Old 01-19-2018 | 07:28 PM
  #55
JB they also have an acedelco one on that same page for $29.79 it says that it comes with bleeder jiggle valves ?
Old 01-19-2018 | 07:33 PM
  #56
Below is a pic of the $30 one with bleeder jiggle valves. Would really like to know if I should go with this one or not
Old 01-20-2018 | 08:33 AM
  #57
jdbaugh1's Avatar
I got one without the bleeder jiggle valve because I didn't know about it until I was comparing the T-stats before I installed the new one. Now I can't remember if this was on my truck or my car but I drilled a tiny hole in the new T-stat in the same location. All it is is a hole with a little ball that rolls around and I think it acts like a check valve. I drilled a small enough hole I figured it couldn't flow enough fluid to prevent it from warming up anyway and haven't noticed any issues. I would say though if you aren't comfortable with the hole you may want to go with bleeder valve though I can't speak for the experience without it. I just didn't want to fight any trapped air. It may work fine, idk.
Old 01-21-2018 | 12:25 AM
  #58
Thanks JB I'm going to go with the ACDelco TSTAT with the bleeder valves to help with any trapped air.
Old 01-22-2018 | 02:41 AM
  #59
Would you recommend replacing the coolant temperature sensor at the same time I replace my thermostat ?
Old 01-23-2018 | 03:12 PM
  #60
Anita Weier's Avatar
I have an 07 cobalt that was running between 190-210F and the other day it shot up to 240 when I got on the freeway, so I changed the thermostat and it’s still doing that.... what else could it be??
Old 01-23-2018 | 03:15 PM
  #61
cobaltssdude420's Avatar
Bad coolant maybe? You can buy a little tester for $5-10. How old is your rad as well?
Old 01-23-2018 | 03:18 PM
  #62
exninja's Avatar
Sure, why not.
T-Stats usually fail open, not closed. It's possible that there is an air bubble in the system, but also unlikely (esp if it's not supercharged). It is likely you have a restriction somewhere, and if so, most likely radiator. Your radiator may be clogged either inside or outside. I'd check that out.
Old 01-23-2018 | 03:24 PM
  #63
Originally Posted by exninja
Sure, why not.
I don’t think it’s supercharge not sure though, I don’t know anything about cars... it’s a coupe, temp sensor was changed a few months ago and ran fine til our temperature went into single digits was running around 217 with outside temp 8. It was staying between 210-217 then one day I got on the freeway and it shot up to 240. Will check radiator, thanks for replying.
Old 01-23-2018 | 03:28 PM
  #64
exninja's Avatar
Just FYI-temp sensor is different from the thermostat
Old 01-23-2018 | 03:29 PM
  #65
I don’t know, bought it may last year. Took it to a Chevy dealer and had everything checked out the day I bought it including transmission fluid, so if it coolant was bad wouldn’t they recommend replacing?
Old 01-23-2018 | 03:31 PM
  #66
I know that, was just putting it out there that it was changed.
Old 01-23-2018 | 03:35 PM
  #67
jdbaugh1's Avatar
Anita Weier, do you have a check engine light on?
Old 01-23-2018 | 03:38 PM
  #68
No, no check engine light on.
Old 01-23-2018 | 03:43 PM
  #69
exninja's Avatar
Dex-Cool lasts a really long time. I think the owner's manual recommends changing after 100k miles. It pretty much only "goes bad" if it is exposed to air or is mixed with standard green coolant. What color is your coolant (green vs. orange vs. brown)?
Old 01-23-2018 | 03:48 PM
  #70
Orange.
Old 01-23-2018 | 04:08 PM
  #71
exninja's Avatar
That's good. My VW had a clogged radiator. The fins were filled with crud and I think the inside was likely cruddy as well. It ran warm till I replaced it. The water pump also leaked, which likely introduced air into the coolant, which is bad news for OAT/HOAT coolant like Dexcool.
Old 01-23-2018 | 06:36 PM
  #72
I thought they didn't make dex cool anymore? I was just at Napa and they don't carry it. Pretty sure Canadian tire doesn't either. I just mixed in Prestone universal coolant and it's ran fine for over 20k...although, it's mostly prestone now. Most of the original fluid was drained.
Old 01-23-2018 | 06:48 PM
  #73
Prestone sells dex-cool. it comes in a grey bottle.
Old 01-23-2018 | 07:08 PM
  #74
exninja's Avatar
They def still sell dexcool. Try walmart if they have those up there.
If you want to get bored about different coolants, try this:
It's geared for VW G-series, but Dexcool is similar in concept.
Old 01-23-2018 | 07:32 PM
  #75
What do you know, your right lol. I have the prestone all makes all models formula and it looks like they have prestone dexcool approved too. I can't see there being much of a difference but I'll read up on it.
