engine dropped a valve after dealer service, warranty wont cover repairs
Old 06-29-2008, 02:08 PM
  #51
bridfi's Avatar
so i hear, i would imagine they do good work, because they specialize in ecotec engines
Old 06-29-2008, 02:22 PM
  #52
D4u2s0t's Avatar
Originally Posted by SlowBalt_06
see bout your sayin that "the car has seen well over 6100 rpms before the service work was done"
but then ..."this car's rev limiter is set to 6500 RPMS, and the second it sees 6100 RPMs, it has a problem, YES"
that was not engineered to be abused it was made for fuel eco.....i would understand more if it was a ss.sc or a tc...then yes but the ls and lt is fuel eco
bro, you're talking like a fool.
you're saying that since he had his car at 6100 rpms it IS abuse, and should NOT be covered? if it's not safe for an engine to be at 6100 rpms then the car in STOCK FORM should not be able to go to that level of rpms. it is not abuse, and shouldn't be considered abuse.
Old 06-29-2008, 02:29 PM
  #53
bridfi's Avatar
that's my argument. let's see if they agree with me...
but i was talking to a guy at bates engineering and he told me that the factory valve springs do actually float at 6100-6200 rpms, i think that is a bad bad idea on gm's part to set the redline above valve spring floating point...
Old 06-29-2008, 02:42 PM
  #54
madmark's Avatar
Originally Posted by bridfi
found out it was 2 defective lifters. dealer replaced exhaust cam, head, the 2 lifters, and also 4th gear synchronizer, under warranty.
thats enough right there, when they get a new head its pretty much blank, you have to swap parts over including valves, springs, cams ect. most likely they didnt properly put the valves in. fight it and dont give up
the car should beable to do 6500, i went from 3rd to second (bad miss) and the rpms went to 8500...... i was scared shitless, pulled over and it was fine...
Old 06-29-2008, 10:36 PM
  #55
bridfi's Avatar
yep thats what im thinking, they just didnt properly install that valve, i find it interesting that i got no keeper back, im sure it was the keeper that was installed incorrectly.
im not giving this one up, im fightin til the end
Old 07-04-2008, 07:19 PM
  #56
bridfi's Avatar
arbitration hearing is july 17th.
turbochargedss2012
09-20-2023 12:17 PM
HEATON
10-16-2015 07:21 PM
SlowSaturn
09-28-2015 11:03 AM
grampss
09-27-2015 08:51 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: engine dropped a valve after dealer service, warranty wont cover repairs
