Error codes
Error codes
Check engine light is on. Giving error codes p0341 and p0141.
I know that the p0341 is the "Camshaft Position Sensor" and the p0141 is the "O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 2"
Does any one know where these are located and have the part numbers for replacement?
I've searched a few places but no luck.
Thanks
Thanks
Camshaft sensor is on the back side of the engine towards the drivers side, there's a housing there that has a sensor pointing almost down out of the back of it.
The 'Sensor 2' means it's the downstream one after the catalytic converter, so it's way down the exhaust. Only accessible from under the car, it's on the side of the exhaust pipe about under the front seat area.
Check www.rockauto,com for the parts if you want aftermarket, or CrateEngineDepot.com or your local dealer if you want original stuff. Although you can find AC Delco parts on rock auto as well usually.
OrangeCoba
09-25-2015 06:06 PM
