Failed Emissions.... HELP
Old 04-10-2008, 12:41 PM
sick06cobalt's Avatar
So Yeah I just failed emissions for the cat.... any ideas on what to do? I have a zzp dp with a high flow cat... I think my cat is fried and thats why i didnt pass...
I think i could just buy another magnaflow high flow cat and weld it in... what do you guys think?
I have the midlength header and dp and dont have the stock exhaust so can someone help me?
Old 04-10-2008, 12:42 PM
FZWCobalt_09's Avatar
Yeah i just bought a cat and welded it in to my old truck! its not that bad. I would do that first and go from there.
Old 04-10-2008, 12:44 PM
yeah... but i dont know what cat to get and i want a highflow because if i put an OEM one in theres no point of keeping the dp then lol
Old 04-10-2008, 12:50 PM
brandondrecksage's Avatar
why did you fail? are your throwing codes for the cat, or because the cat isn't factory
Old 04-10-2008, 12:51 PM
07ss_PJ's Avatar
get your car registered in a state that doesn't do emissions. works like a charm.
Old 04-10-2008, 12:54 PM
kissmySS's Avatar
better yet why are ya ever testing it... its brand new...?
Im a certified Emissions tester here, but our rules are different..
rockkrawler628's Avatar
Emissions Law Change...
as of april 27th or 21st can't remember... the emissions laws will change.. if the O2 sensor isn't ready (went through its readyness test) it won't pass emissions
this is only for PA as far as i know
Old 04-10-2008, 12:57 PM
Its the same in MO they said I have about 20 days to fix it... I need to renew my registration so i can drive my car lol... i think its kinda important
Its not brand new i got it on about 5 months ago after the group buy... i think its fried anyway...
I have been throwing PO420 lol
Last edited by sick06cobalt; 04-10-2008 at 12:57 PM. Reason: Automerged Doublepost
Old 04-10-2008, 12:59 PM
07LaserBlueSS's Avatar
Schuylkill county still doesn't inspect emmission
Old 04-10-2008, 01:10 PM
well good for you lol but that doesnt help! lol
and cats arent freaking cheap....
Last edited by sick06cobalt; 04-10-2008 at 01:10 PM. Reason: Automerged Doublepost
Old 04-10-2008, 01:15 PM
Cobaltss/TC's Avatar
dude bolt back on the oem cat, drive for a couple days go take the test pass it and then switch it back over, not to hard.
Old 04-10-2008, 01:28 PM
I cant... read the OP... I dont have the stock dp and the stock one wont bolt back on to the existing header...
Bump!!!!!!
Last edited by sick06cobalt; 04-10-2008 at 01:28 PM. Reason: Automerged Doublepost
Old 04-10-2008, 01:29 PM
Rent me! per hour
Area47's Avatar
put the stock cat back on the car. go have it done. then swap out later.
Old 04-10-2008, 01:30 PM
Altiery54's Avatar
move to my town we dont have emissions!!!
or that
I could do that... hmmmm but wouldnt the dimensions be off?
Old 04-10-2008, 01:31 PM
Psykostevo's Avatar
Just have the CODE disabled in your tune, not just the light.
And before you ask......that means don't just uncheck the P0420 code, you need to go into the options to the right of the check box and change it to 0 - No Error Reported.
Old 04-10-2008, 01:32 PM
im a 2.2, I wish i had that capablility
Old 04-10-2008, 01:34 PM
good idea ^^^^^^^
poppagun's Avatar
by my car it will pass
(if it could get there.)
p.s. Never mind it womt do either one i lied
Old 04-10-2008, 01:35 PM
Rent me! per hour
Area47's Avatar
if you have an lsj manifold, or stock 2.2 manifold. it should line up
Old 04-10-2008, 01:52 PM
but i dont..,.. i have the midlegth header/dp combo... and dont feel like removing the header again to do this
Old 04-10-2008, 01:54 PM
not sure what to tell you then besides registering somewhere else.
Old 04-10-2008, 01:57 PM
lol i would.... but.... lol
Old 04-10-2008, 02:05 PM
LSX RWD S/C conversion
victory_red_SS's Avatar
If the choice is to repeat the work or not driving, I guess you will be doing the work, even if you moan about it for 18 more days.
Old 04-10-2008, 04:46 PM
true.... ill probably just end up doing this tonight...
Last edited by sick06cobalt; 04-10-2008 at 04:46 PM. Reason: Automerged Doublepost
Quick Reply: Failed Emissions.... HELP
