Four Codes after Dealer Cat Replacement
Had these pop up after dealer replaced my cat converter:
P0030
P0053
P0102
P0443
It was running great for about 20 miles then just started running like ****. Any ideas? I thought maybe the dealer erased my hp stage 2 tune and put the stock one back on, but it still revs out to 7k.
P0030
P0053
P0102
P0443
Originally Posted by footballplaya3k
Didn't you also say there's no power gain from removing the cats?
A catless downpipe will give you less than 5whp. I think you'll gain about 2.
Does Washington not have access to Google?
https://www.google.com/webhp?sourcei...%20dyno%20test
Just use a high flow cat if you need MAX POWAR from your Chevy Cobalt, which from your sig looks like you've already done.
You are not very smart:
Dyno testing has proved that to be true. Mike Osucha says: "We
recently built a 396-cubic-inch LT1 engine that produced 455
horsepower with an open exhaust system. When we installed two
high-flow converters, the engine produced 458 horsepower.
No, I used to be catless and it made the car sound and smell like ****. I tried resonators in place of the cat, different catbacks... thousands of dollars using different setups. The best is stock with a ported manifold. When you get into headwork and other major mods then it makes sense to open up the exhaust. On stock heads/intake manifold/sc/turbo it's a waste, just makes you sound like a ricer in traffic all for about 10whp.
