front suspension = clunking noise?
Old 08-08-2006 | 04:14 PM
  #76
hardtocope's Avatar
i sent gm a email today about the steering thump in my car and how the dealership replaced the intermediate shaft and it's still doing it again. Now the dealership says the thump in my steering is normal and can't do anything about it. Hopefully gm will do something about it.
Old 08-08-2006 | 04:16 PM
  #77
BLKSS's Avatar
I had the same problem you described. Just so happens my front rims were loose. It happens when you travel high speeds with alluminum rims, they work alot. Tighten them by hand.
Old 08-08-2006 | 04:18 PM
  #78
hardtocope's Avatar
it's def not my lug nuts. It usually happens at low speeds going over bumps or even better on gravel roads.
Old 08-08-2006 | 04:19 PM
  #79
hardtocope's Avatar
Originally Posted by WJT DEMON
I'm getting the front stab links replaced. I am quite sure thats what the noise is. Jack the front end up and give the links a wiggle and will probably hear it.
Did having the links replaced fix the problem?
Old 08-08-2006 | 04:24 PM
  #80
BLKSS's Avatar
Im telling you i never thought it could of been that. I was reproducing the noise rocking back and forth in reverse. Just check and see.
Old 08-08-2006 | 04:26 PM
  #81
CTCOBALTSSS's Avatar
They better do something about it. I have same thing along with all of you. I don't care what they say, that is not normal. It almost feels loose and it's very annoying.
Can someone say recall?
Old 08-08-2006 | 04:28 PM
  #82
hardtocope's Avatar
i know it's not the problems, because i've taking my factory rims off to put aftermarket rims on and vise versa several times. I've had this clunk since day one when i bought this car. But that sounds really dangerous that ur lug nuts were loose, good things you found out.
Old 08-08-2006 | 04:29 PM
  #83
BLKSS's Avatar
Techs will allways want to fix big things that arent broken. More money for them.
Old 08-08-2006 | 04:30 PM
  #84
BLKSS's Avatar
i know it's now the problems, because i've taking my factory rims off to put aftermarket rims on and vise versa several times. I've had this clunk since day one when i bought this car. But that sounds really dangerous that ur lug nuts were loose, good things you found out.
Yeah, thats what happens when you drive it way over the speed limit for long periods of time.
Are you sure you didnt break an axle? It kinda sounds like it. Maybe your bearing in the transfer case is fucked. I dunno.
Old 08-08-2006 | 04:31 PM
  #85
hardtocope's Avatar
i don't think they will do a recall since it's not dangerous supposeldy. But this is really aggravating because it seems like a lot of cobalts have this problem and everything they do to replace it just doesn't work. I really wanted to lower my car but am worried the problem will get worse if i lower it.
Old 08-08-2006 | 04:33 PM
  #86
Well I had the clunk well before lowering my car. I have Eibach sportlines and the problem has not gotten worst at all. It's just annoying.
  #87
hardtocope's Avatar
I meant i know it's not the problem. Like i said i had this problems since day one when I bought this car. Theres on way it can be the rims, i always make sure there tight. I really have no idea what the problem could be.
Old 08-08-2006 | 04:34 PM
  #88
hardtocope's Avatar
Sweet, that gives me some peace in mind when I go to lower my car.. I would have lowered my car a long time ago if i didn't think the problem would get worse.
  #89
hardtocope's Avatar
i sent a email to chevy about this problem and that my dealership isn't doing anything about it.. do you think chevy will do anything about it?
Old 08-08-2006 | 04:41 PM
  #90
BLKSS's Avatar
Your dealership won't help you? Call GM services and tell them that and they will flip on them. They should keep your car and if they can't figure it out ask them for a rental. You can allways try another dealership.
Old 08-08-2006 | 04:44 PM
  #91
Honestly I highly doubt it. They couldn't even put badges in our stage kits nevermind recalling all of our vehicles for suspension work. GARBAGE!
Old 08-08-2006 | 04:47 PM
  #92
extremechevy86's Avatar
i work in a chevy dealer ship and were finding out that this noise is not comming from the intermediateshaft its in the steering column. Chevrolet is tellin the techs to replace the shaft and then when that dosn't fix it to replace the column. We haven't had a shaft fix the noise yet but the column has.
Old 08-08-2006 | 04:51 PM
  #93
Hmmmm. So it's a colum thing hah? What is it about the colum? Any idea? Thanks
That's a heck of a 1st post BTW interesting.....
Old 08-08-2006 | 04:54 PM
  #94
hardtocope's Avatar
how big of a project is it to replace the steering column? i have a stereo in my car should i remove it first?
Old 08-08-2006 | 05:13 PM
  #95
Chances are that's a fake post bro. Like I said, that's one heck of a 1st post!
Old 08-08-2006 | 05:22 PM
  #96
YellowLT's Avatar
Originally Posted by Crunchy
I hear the same thing but it seems like only when I take off, or turn my steering wheel as soon as I take off.
This Is a TSB on The Intermediate shaft on the Steering linakge to the steering pump they replaced mine no more problems
Old 08-08-2006 | 05:31 PM
  #97
So the clunking is gone for you? How long did it take them? Thanks...
Old 08-08-2006 | 09:31 PM
  #98
hardtocope's Avatar
the dealer replaced my intermediate shaft and still freaking does it.. but like i said they say the little thump i get in my steering wheel is normal????
Old 08-09-2006 | 02:33 AM
  #99
zzzzzzzz's Avatar
ok went to dealer today they called gm and told them all the things they did to my car that didnt work and guess what im going to be the proud owner of a new redesigned sterring colum lol 1500 bucks hope this works lol i feel like a guinne pig
Old 08-09-2006 | 10:50 AM
  #100
hardtocope's Avatar
when will they be recieving the new steering coloumn. Also does anyone know how big of a job a new steering column is?
