Frozen display on dash
So I wanted to check the outside temperature. It would not move,the display just reads the trip, it will not cycle thru the reading like oil % or tire pressure. Tried hitting the info button a number of times still frozen. Turned the car off and came back an hour later same thing .
Ideas?
09 TC/SS
Ideas?
09 TC/SS
The other buttons work like volume& mute .The cruise control lights up. I live in Laguna Beach, CA it gets maybe 50degrees at night. I got it to cycle once today. Then it froze again. At least it's stuck on mileage and outside temp. Traction control works too. Love Competition mode on PCH
I wonder if there might be some pinched wires, or if the clock spring might be going bad. I know that'd give you an airbag light, but the wiring goes through that part. These buttons can be taken apart to clean out, you just have to be careful with them when you're removing them down to the circuit board.
