fuel filter questions
Find a plastic pen cut it about two inches long then cut it down the centre ...don't forget to remove the ink stick first you might have to have three pieces if the pen is small ..just do it again with the same pen
You have a pen right not a bick like a blue coloured pen on the outside the smooth ones round one....take the tips off take out the ink stick cut the pen in half like two inches then that piece cut in half long ways. Tada quick release tool lol.
AutoCraft 6 pc A/C and Fuel Line Quick Disconnect Tool Set AC502: Advance Auto Parts
I have this one:
Lisle/A/C/fuel line tool set LIS37000 at AutoZone.com
It's either 5/16 or 3/8.
I have this one:
On the intake tube inside the driver side fender well. I can't remember if you can remove it by pulling the headlight or not. Probably best to put a new air filter in while you're at it. So plan on pulling the tire and then removing the wheel well liner to get at the filter housing.
Sounds good. Moving to Orlando in june and trying to get the car in as close to perfect condition as possible. Hopefully these fixes will,solve the a/f issue I've been having every since I dropped the new motor in.
