fuel pump harness pinout
Old 01-09-2016 | 07:47 PM
rousseaus99's Avatar
Ive looked everywhere I need the fuel pump pinout on the harness connectors that goes to the tank that plug into the cars body connector
Old 01-10-2016 | 10:47 AM
TStone's Avatar
what year and stuff
Old 01-10-2016 | 10:49 AM
TStone's Avatar
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A
RD/WH
1840
Battery Positive Voltage
1A
RD/WH
1840
B
WH
1310
EVAP Canister Vent Solenoid Control
1B
WH
1310
C–D
Not Used
1C–1D
Not Used
A
BN
882
Right Rear Wheel Speed Sensor Signal (JL4/JL9)
2A
BN
882
B
WH
883
Right Rear Wheel Speed Sensor Low 2B Reference (JL4/JL9)
B2
WH
883
Right Rear Wheel Speed Sensor Low Reference (JL4/JL9)
C
BK
884
Left Rear Wheel Speed Sensor Signal (JL4/JL9)
2C
TN
884
D
RD
885
Left Rear Wheel Speed Sensor Low Reference (JL4/JL9)
2D
OG
885
A
BK
850
Ground
3A
BK
850
Ground
B
TN
510
Fuel Sender Low Reference
3B
TN
2759
C
GY
120
Fuel Pump Supply Voltage
3C
GY
120
D
PU
1589
Fuel Level Sensor Signal
3D
PU
1589
E
Not Used
3E
Not Used
F
GY/BK
2709
5-Volt Reference
3F
GY
2709
5-Volt Reference
G
D-GN
890
Fuel Tank Pressure Sensor Signal
3G
D-GN
890
H
BK/WH
2759
Fuel Tank Pressure Sensor Low Reference (2.2L/2.4L)
3H
TN
2759
3H
TN
2759
Old 01-10-2016 | 10:52 AM
2006 thanks
Old 01-10-2016 | 11:02 AM
TStone's Avatar
that's for an 07. should be the same. hopefully. if you have trouble reading that let me know i'll screenshot si
Old 01-10-2016 | 11:05 AM
TStone's Avatar
View image: Screen Shot 2016 01 10 at 10 02 58 AM
if someone sees it can they just post the img thing so it shows the picture? thanks
09ssbeast
24
04-05-2016 05:28 PM
Crav3
01-12-2016 04:38 AM
Jesus123
01-09-2016 09:25 AM
rousseaus99
01-07-2016 12:41 PM
BA89
01-06-2016 12:44 AM
Quick Reply: fuel pump harness pinout
