getting very annoyed can anyone please help
i have been having an issue with my car ever sense i installed my return fuel setup. when ever im below a quarter tank of gas and give it alittle extra gas( basically when im in boost) the car when start acting like its not getting and fuel. i redropped my gas tank and made sure i had everything installed correctly(which it is) the only thing i did not do on this install is upgrade the fuel pump. i am running 80 pound injectors on a tvs w/ a 2.8 pulley on e-85. but it was doing this before i even got tuned for e-85. anyone have any ideas?
My car does this too, but I'm stock even. The only thing I can think of is you are maxing the injectors out. I know that the stock injectors are at 120% capacity..
Sounds like an issue with the pick up, only reason I can think of that it would do it only below 1/4 tank.
im gonna order a new pump friday and try that route. are our tanks pressurized? could it be because im losing pressure and its not sending fuel like it should? i also never bought that piece that goes in your fuel line for when u get a return fuel system. i cant remember what its called but it stops the fuel from goin back through the lines when the car is not turned on
breds2k
19
09-21-2015 10:24 AM
