GM dosnt have a fix??!!
Man , I just dont get all the sporadic PCM issues , I thought it was just early build 05's, but now its in some of the 2006's too? . My 05 was built 5/05 so it was one of the early ones , and I havent had 1 single CEL or oddity at all and I just turned 15,000 miles .
Sorry for the people having the problems , man that sux .
Originally Posted by GeoChevyCobalt
Mine did that for a little and then I got a re-flash and it stoped. I think once you put some miles on the car it stops. Also the cold start re-flash helps with this issue.....
GM is investigating this issue as we type, ive called head office, i told them a day after i had the car this idle crap started happening and was not impressed, since then they have phoned me 3 times sayin they will find a fix and take care of this issue. well just wait and see.
Originally Posted by dimeo09
Get your car reflashed.... even if they say it has all updated codes... they are wrong, i reflashed my car with the same issue (idle problem) and now its idle mint
GET IT REFLASHED ... the end
mken - I think you need to find a new dealer if you can . The passenger door issue was taken care of on mine and they were aware of the bulliten . GM has actually made a bigger bezel for this problem , how could they not know about it .
Originally Posted by mken
I've yet to have met anyone at the Bill Heard Chevy around here with a clue.
My car does this too. Its rare, and has happend on my 06 balt since I first got it. My simple quick and easy fix is as follows:
Hit the gas....
Thats right when it starts bouncing just tap the gas once and boom, problem gone. it doesnt happen all too frequently so when it does thats enough of a fix for me now. As soona s you touch the gas it stops, so until there is a fix, that should hold you down.
Hit the gas....
Just wondering,
is this only affecting the SS S/C, or are regular SS 2.4L affected also?
I'm planning on getting the 2.4SS this spring and I'm wondering if it will also have this problem. And unfortunately, I dont have the cash for the s/c, or the extra insurance.
#37
Hit the gas....
Hit the gas....
#38
Originally Posted by MarcS
I would suggest taking it to another dealer to get a second opinion on that. There certainly is a service bulletin on the idle issue.
#40
I got my 05 SS last June and it did the same thing when I was stopped at a light. A little while later, the baffles in the muffler went and I had to get a new muffler. When it came, they put the new muffler on, re-tuned the car and re-flashed the ecu. The problem with the idle at a light never happened again after that. Thank god my muffler blew.
#42
I had that idle problem..so i took my car in yesterday to get it checked out. The tech said that since my car is an 06' my ECU has all the right programs in it, even the idle control. He said not to worry about it and i dont need a reflash or nething. If it does it some more then ill go back and demand one
#43
I just bought an SS/SC two weks ago and was just noticing the idle problem. I'm glad I now have some information to bring with me when I talk to the dealer about this. (Some people always assume us ladies are clueless and fail to listen to us). Hopefully this will get resolved because I LOVE my SS. (Sooo much more than my Neon I sold).
#44
I hate this fawking idle issue.. It also happens on my 06 SS/SC. Its a HUGE **** off.. I dont understand why they would even sell the car when it does something like this. Since the car comes with a exhaust you can actually hear.. Its embarrasing..
#48
ok boyz and gals, car goes in monday, they will be flashing it again even though they said i have all the updates, they are also fixing the door pillar vinyls that are bubblign and peeling and my wing insert on the passenger side is kinda fallin off so they are gonna fix that too, ill let u know the outcome.
#50
i hade bought my car 2 weeks ago, ss/sc/06 at 500kl the cars idle keeps droping 3rpm then back to normal idleing so i brought it in they said they upgraded the software and that was the problem ,well it wasnt the problem cuz the day after i was driveing around and it kept doing the same thing ,hopefully this time when i bring it in they actually fix like there trained to do ,
