GM uses cheap aluminum
Old 03-06-2007, 07:45 PM
Blue_ghost's Avatar
Thank you for the info Doc!
Old 03-06-2007, 07:54 PM
BLKblurr06's Avatar
I could be wrong, but I dont think the oil pan is made of aluminum.
Old 03-06-2007, 07:55 PM
06blackg85ss's Avatar
every thing is aluminum man... tranny housing, block, head.
Old 03-06-2007, 08:00 PM
OniMirage's Avatar
i think a 6 speed would hurt us more than help us unless you had much better gear ratios
Old 03-06-2007, 08:07 PM
jeremie's Avatar
would you rather them use cast iron and end up having a car that weighs twice what it should?
Old 03-07-2007, 08:08 PM
smartmlp's Avatar
SAAB or Opel, it doesnt matter, its all GM. So saying its not made by GM is false.
Old 03-07-2007, 09:02 PM
Fail Less.
Bika's Avatar
thank you. gm > saab.
my tranny didnt crack at the exterior of the bellhousing. the case cracked inside the bell housing, covering my clutch and flywheel in oil.
my oil pan was not hit by anything internally or externally. i barely EVER drive this car. never had severe wheel hop
as for the comment about the civic Si, im not going to get started. not the time nor place.
Old 03-07-2007, 09:06 PM
halfj99's Avatar
wow your smart...Gm=Saab
Old 03-08-2007, 10:10 PM
Fail Less.
Bika's Avatar
hey halfass99, YOU'RE smart. we all know gm and saab are equal, saab is part of GM.
Old 03-11-2007, 05:15 PM
sensesfail99's Avatar
Originally Posted by Meatball
My oil pan got a hairline crack in it from hitting a pothole going up an off ramp. The dealership refused to warranty it. damn our cars for sitting so low.
Get a hold of your states d.o.t. and file a complaint. This happens frequently in washington on the on ramps. people get flat tires, damaged rims, oil pan problems. and the dot will most of the time write them a check to get the items fixed and then they also go out and have the pothole filled so it doesnt continue to be a problem.
Barkleyj605
10-24-2015 12:07 AM
cavfiredesire
10-03-2015 08:02 PM
nathan112i
09-30-2015 07:12 PM
Dylan Johnson
09-30-2015 08:57 AM
Josh@ottp
09-17-2015 12:03 PM
Quick Reply: GM uses cheap aluminum
