having a bit of an issue
ok guys i have a 2010 base model cobalt with a 2.2 engine. no mods done to it. so far this has happened twice. i press on the gas and my car slowly speeds up, even though i have it to the floor. is it having problems shifting gears? its a automatic. and suggestions on what i should do? i do know if i let off the gas for a few minutes and press it again, it fixes the problem. what would be causing this?
The 4 speed autos have a bit of a sweet spot for downshifting to 2nd. If you're going just a little bit to fast the car will keep you in 3rd. All GMs are like that. Its a programming thing.
i had an 07 2.2 for awhile, but standard...if i came to a stop and went to go...just giving it a little gas it would rev up like crazy and wheel hop till i let off the gas....it was nuts...i almost got me into an accident twice and im sure my axles didn't like it...they found it to be a faulty issue with the tb.... the tb was interpreting the info as me stomping on the accl when actually i wasn't... i dunno anyway it was replaced under warranty and it fixed the issue.
