headlight issues...
Old 01-14-2013, 07:52 PM
headlight issues...
They turn on when i hit unlock on my keyfob
When i turn on the car they do not turn on, nor when i flip the headlight switch.
I have hids
Anyone experience something like this?
Might be the issue... Heres my relay harness. Only thig thats wierd about it to me is if the relay harness is bad wouldnt these lights not turn on at all?
Old 01-14-2013, 08:05 PM
AWD > FWD
TommyP's Avatar
if that relay is not bad now, it's going to be soon. You're supposed to put those somewhere that they won't get wet, like up in the frame rail. Replace that relay harness and it will probably be fine
Old 01-14-2013, 08:11 PM
Got Brakes?
Sox-Fan's Avatar
Tommy's right. Water inside, corrosion outside. They need to be protected. And probably cleaned every now and then. Guess I know what I'm doing Saturday.
Old 01-14-2013, 08:12 PM
Yea im gonna either way once i get money. But ts wierd that it works when i hit they key fob but not when the car is on.
Anyone know where the headlight switch is or if it might be the signal switch deal or something?
Old 01-14-2013, 08:16 PM
Rick Bragstad's Avatar
I just had the exact same issue, but don't have HID's. When you unlock the car the brights come on till you get in. When you start the car the low beams automatically come on, DRL if daylight or low beams at night. I checked the relay, fuses, power at the harnesses, all good. Checked the bulbs, both low beam bulbs burned out at the same time. Coincidentally it was the the day I got the car back from the dealer after my ignition switch got stuck on while the car was running. Switch replaced under warranty, bulbs burned out just hours after I got the car back, but thats another story. Check for power at the harness to the lights, swap high beam bulbs to low beams and see if they light up. Replace if necessary.
Old 01-14-2013, 08:52 PM
Thanks for the input man. Sadly its not the bulbs they are single bulbs retrofitted and they are both good
Old 01-14-2013, 08:53 PM
Got Brakes?
Sox-Fan's Avatar
Trying to remember if the relays are left/right or high/low for the bi-xenons.
Old 01-14-2013, 08:59 PM
RyBread761's Avatar
Am I the only one that found these headlights the hardest ever to reinstall? Putting my new bezels in nearly made me go nuts.
Old 01-14-2013, 09:00 PM
Got Brakes?
Sox-Fan's Avatar
no?
Old 01-15-2013, 12:14 AM
Wepl ive had my headlights in and out of my car a million times. Its like it never gets old. :rollseyes:
They are always kind of a pita to take out and to reinstall
Old 01-15-2013, 12:24 AM
Got Brakes?
Sox-Fan's Avatar
Why do you have to take the headlights out to unplug the relays and plug new ones in? To relocate them to a cleaner place maybe, huh?
Old 01-15-2013, 12:27 AM
I'm too JDM for you
BLAZIN07SS's Avatar
Relays definitely need to be replaced. Start there. They need to be put somewhere they aren't going to get wet in the future.
Old 01-15-2013, 12:32 AM
AWD > FWD
TommyP's Avatar
Not even a little. I can probably remove and replace cobalt headlights in less than 30 seconds. Have you ever had a car you had to completely remove the front bumper? Go from a 5 min headlight bulb change, to 45 min
Old 01-15-2013, 11:16 AM
ok i ordered two new relay boxes or whatever those are called lol
this morning i found out that my brights do work though? had to drive to work like that. this is so confusing.
Old 01-15-2013, 11:21 AM
Got Brakes?
Sox-Fan's Avatar
That's why I said this:
Old 01-15-2013, 11:48 AM
AWD > FWD
TommyP's Avatar
can still be the relay is bad. The one time I blew a relay due to water, whenever I turned on my headlights, my high beams were stuck on. New relay fixed it.
Old 01-15-2013, 11:56 AM
kdub1492's Avatar
I honestly would have just ordered the new TRS harness...
Old 01-15-2013, 11:57 AM
oh good point that could be the case.
it could also explain why i came out to my car one morning and headlights were stuck on no matter what. seems it is sticking or something. o well well see how fast the new relays come in.
where do you put yours? somewhere in the engine bay?
Old 01-15-2013, 11:59 AM
Got Brakes?
Sox-Fan's Avatar
Yes, but up way high and behind the radiator support. I'll try to snap a picture later on today.
Old 01-15-2013, 12:00 PM
Got Brakes?
Sox-Fan's Avatar
A lot of money spent if it's a 5 dollar relay.
On the other hand, a lot of time lost if the plug is corroded to the point where it won't accept a new relay.
Old 01-15-2013, 12:03 PM
kdub1492's Avatar
Yea kinda a double edge sword...relay harnesses are a pain in the ass. With my last on I put it inside a balloon and have the wires faced down so nothing can get to it...
Old 01-15-2013, 12:08 PM
^good idea. i just don't have the money for a whole new harness right now, kinda sad but true
the relays pop out easy, and i can see the connections are also kinda shitty and green. i'm gonna use electrical parts cleaner and fix them up a bit for the new ones
whats the new trs harness anyway? i was having troubles finding the current one im using on their site
Old 01-15-2013, 12:26 PM
kdub1492's Avatar
Yea the current one you are using is old. prolly about 1.5 years ago that one stop being made. The one that I have is this one...
Bi-xenon: 'MotoControl 9004/9007/HB5 - Relay Harnesses from The Retrofit Source Inc
this is their new montocontrol harness. It is pretty sturdy and I guess the wires they use are better grade? idk..just something new to sell IMO haha
Old 01-15-2013, 12:36 PM
mkulrey13's Avatar
We sell anything Morimoto and pretty much anything on that site for less. I for one LOVE the new harness's
Old 01-15-2013, 12:43 PM
cool. i'll save this for 'next time'... theres always a next time with me and headlights
Quick Reply: headlight issues...
