headlight wire question. help!!!
as you can see on the headlight side there is 3 wires. which ones are the low beams and high beams? one is like a like pink. the other color is red. I need help so i can hook up my fog lampts today. Thanks a lot
ryan
Trying to recall from my HID install...
I believe the orange wire are highbeams. If not, unplug one (use a toothpick on the backside of the harness to remove the wire) then hit your unlock on the keyfob. Apparently they're highbeams. Only your DRL/Parking light will turn on.
