headlight wiring help
I'm not really sure which thread to put this in so if it needs to be moved go for it.
Background, I have gen 1 LED/halo projo's and an M62 on my L61 if it matters...
So heres the problem, on my passenger headlight only the halos and LEDs work, my high beam and my low beam both don't work. My driver headlight is 100% fine. It's not the bulbs because I tried other ones. I replaced both fuses and as far as I know the wires shouldn't be crapped out yet on an 07. Any idea whats going on? I'm stumped
thanks in advance!
thanks in advance!
Swap headlight units, wire them up, and see if problem is still with Pass.Head. If problem stays on pass.side, then it's most likely a wire issue before unit. If problem follows to driver side, then it's tha actual housing ^^ GL
