headlights... really pissing me off....
Ok I've posted all over looked all over and my question gets lost or not acknowledged.. I'm really getting fed up with this issue. I've checked fuses, replaced multifunctional stalk and still same ****. I'll explain in a nutshell...
When I push the turn signal lever away from me, the low beams turn off and there are no high beams (just the side lights are lit). When i pull the lever towards me, the high beams flash like they are supposed to. I
I would look for a break in the wiring. This is everything I can think of to check fuses,wiring,broken bulb filament and the malfunction stalk, considering that they worked to begin with.
stalk was replaced.. I even tore down old one before new one got here... guess that was a mistake
if I push forward they come on, but when the stalk is fully engaged forward they come off.
the car does have HID's that have been in for 2 years with no issues till now. I've heard people telling me BCM related?
[QUOTE=low_k3y;739827
the car does have HID's that have been in for 2 years with no issues[/QUOTE]
^Here if your problem. Check your hid wiring and relays. You likely have corrosion or a bad ground somewhere.
If you want to confirm they are the problem and not the bcm plug in the old headlight pigtail and put in a stock bulb.
Oops just noticed you said they will flash if you pull back on the stalk. I would still test it by trying the original pigtail and lights but it is sounding more like the stalk or bcm now.
any way of testing the BCM? or doing a diagnostic on it? just seems like there'd be more problems then just lights. Why can it never be simple for me
I would hit the dealer but I don't want an absurd bill thrown at me. I'm sure having them look for whats wrong will costs $$ as well.
Ok, found issue.. something with my HID's. Canabus ballasts, now what the hell could be cause this? I threw a set of stock lights and and pushing forward worked. My ballast crap out? looking for feedback ASAP
just seems odd the lights work fine normal driving and pulling back.. just not pushing forward?
would not running a harness to the battery to the HID's cause this?
ripped out all the HID stuff not looking forward to night driving now.
if the ballast are bad that's 2 sets in 2 years I've burnt thru. I tried hooking up old relay I had gotten with first kit from mulrey think that harness was shot just made a loud buzzing noise.
I'd love to get a harness knowing it'd fix my issue,not like I bought a set of crappy HID's
I'll hit zzp up.. not sure if it took something out in the ballast.. when I get harness I can test ballast again. I have a spare M90 with TB and ZZP DUB system just sitting around collecting dust. I'll shoot for in store credit.
