heat and air questions.....done a search
Old 05-18-2007 | 02:52 PM
chood711's Avatar
Whats up guys,
I just bought my ss about a month ago. Since I have had it I have noticed that even when I have the blower turned to the off position it still blows out quite a bit of air. Is this normal? thanks for your help in advance.
Old 05-18-2007 | 03:52 PM
fr33k's Avatar
Does it blow out air all the time? I know when the switch is off, the controls automatically set the vents to let air in through the fresh air intake ducts. The faster you go the more air is directed through the vents. If you are sitting still there shouldn't be any/much air at all goin through them.
If it's your motor one the other hand, there is a problem with the controls or relay.
Old 05-18-2007 | 04:01 PM
RaineMan's Avatar
As far as I know that's normal.
I never turn my fan all the way to 0 because it's actually bad for the engine... just like using the MAX AC. (read your owners manual) So it always flows some air.
Old 05-19-2007 | 02:23 AM
chood711's Avatar
i dont know if it blows when the car is stopped havent paid no attention to it. ill check that out though.
Can it really hurt the engine? what can it do?
Old 05-19-2007 | 10:17 AM
RaineMan's Avatar
It's just not letting air flow through from under the hood properly... you are making the engine work harder than it needs to. Read your owners manual... I swear there is something in there about it.
Old 05-19-2007 | 10:26 AM
ted5986's Avatar
i didnt see anything about it. if you dont want it to blow the slight amount of air, then put it on the all-the way left setting. aka the face vent. then hit the recirculate button
no_ss
10-19-2015 12:58 AM
Delta coupe
09-30-2015 09:11 AM
DocSvensk
09-27-2015 03:24 PM
jmelton327
09-26-2015 11:04 PM
OrangeCoba
09-25-2015 07:06 PM
