HELP! Any1 that had the timing chain replaced for TSB!
Somebody please help me out. Anybody that had there timing chain replaced for a TSB. I want more information on this due to the fact the dealership wont do anything to my car unless i take the motor mounts and trans mounts out of my car first. I wanna do my Stage 3 this weekend but my car is F'd up as it makes a screeching noise at idle (sometimes) The dealership drove it and didn't find anything (like i thought they wouldn't) and said i hafta undo the mounts. I'm looking for a TSB number from GM and came up with nothing. Anybody with more information please shed some light on this for me I really appreciate it.
Check this out
https://www.cobaltss.net/forums/show...ht=TSB+thought
This is all that i could find on the timing chain...
https://www.cobaltss.net/forums/show...ght=secret+TSB
and figured this might be my problem:
Check this out
do you know of any TSB # for this or any other information...
anybody??? come on... i PM'd several people with no response doesn't anybody wanna help out a fellow ss.net member??
I called GM and got this freaking guy that doesn't even speak English right... so i hung up and called back... i got someone else and let me tell you... I think it was a total waste of time... The are no help at all... I guess I've gotta take my motor and trans mounts out tomorrow and then take it back to the stealership to have them ******* fix it and don't want it back until it is fixed. Fin A holes... I hate dealerships i should just buy a bicycle
Last edited by rockkrawler628; 03-31-2008 at 10:43 PM. Reason: Automerged Doublepost
PIP#4014 all this states is there is an updated design because of old design flaws and tells service techs about the o-ring that needs to be swapped. Nothing else
yes it is a preliminary info GM doc# 1884273 all it states is there is a o-ring you have to switch over when doing the timing chain because of timing chain failure or tensioner failure.
#PIP4014: Parts Update - Timing Chain Tensioner Design Change - keywords adjuster after change chain chevrolet damage design engine filter hot idle indicator information lamp lash lifter light mechanical no - (Jan 4, 2007)
Adam144
09-03-2015 07:48 PM
