Help Asap!!!
Old 04-15-2007, 09:11 PM
Tazmanian_Dvl's Avatar
i'm just saying do that until you get to the dealership i'm not saying to leave it like that for eternity lol
Old 04-15-2007, 09:19 PM
BlackBaltSSNA's Avatar
lol ah i see sorry about that
Old 04-15-2007, 10:19 PM
I'm old school
Halfcent's Avatar
You have two separate problems. First, the missing flywheel teeth. That's simple enough, yet still very strange that it happen in the first place. Replacement is a bitch, but that's what a warranty is for.
Second is the stall. The flywheel has nothing to do with that. I agree that the water probably played a roll and you soaked something. That's actually the easier of the two problems.
Old 04-15-2007, 10:34 PM
i'm just suggesting you bump start it and make sure it runs. if it's locked up that may be why the tooth is broken off the fly wheel
Old 04-15-2007, 11:11 PM
Cobalt Mav's Avatar
I had heard that if you get water in the engine, you just pull out the spark plugs and crank it over. Don't know if that will work for our cars considering they are all computers.
Old 04-15-2007, 11:30 PM
if you get water in your engine you are totally screwed! the cylinder walls will rust and when the piston moves it will scrape the cylinder walls and leave gouges which will cause compression loss
Old 04-16-2007, 12:27 AM
I'm old school
Halfcent's Avatar
Water in your engine won't just kill it. You would need to hydrolock the engine to really damage it. Rust will only happen if you don't clear the water out AND don't run the engine for a while. If you get some water, the normal process of the engine running will usually clean it out for you. If the engine stalled, then the removing the spark plug trick is helpful, but not for the laymen.
Cobe
09-19-2015 11:04 AM
06noscobaltss
05-25-2006 01:55 PM
Saki XL
05-16-2006 01:34 AM
9JordonFlex9
03-26-2006 08:05 PM
Cobalt30
03-11-2006 02:50 AM
Quick Reply: Help Asap!!!
