Help: Boost leak test results.
Hello, after blowing my Injen upper cp off i decided to do a boost leak test to insure a tighter fit the second time around (still waiting on the upgraded coupler kit) While performing the test i sat my regulator on my compressor to 20psi. I did not hear any leaks from the charge pipes them selves but I did hear air coming out of my CIA ... I had the pcv disconnected so i know it was not coming from there. The first time i boost leak tested I still had stock air box so im not sure how long this has been occurring. My question is how bad is it? Is it a bad turbo (first turbo car) or as i might fear something wrong in my valve train? Please let me know anything will help. car still runs and drives fine and will still pull if i want it too. I will be doing a compression and blow down test here shortly (If there is a how to about disabling ignition let me know so i can run these tests) Thanks for stopping by!
Bump, slightly revised version. Hello, after blowing my Injen upper cp off i decided to do a boost leak test to insure a tighter fit the second time around (still waiting on the upgraded coupler kit) While performing the test I set my regulator on the compressor to 20psi. I did not hear any leaks from the charge pipes them selves but I did hear air coming out of my CIA ... I had the pcv disconnected so i know it was not coming from there. The first time I ran a boost leak test I still had the stock air box so I am not sure how long this has been occurring. My question is how bad is it? Is it a bad turbo (first turbo car) or as i might fear something wrong in my valve train (seals, bent valve, cracked retainer, ect)? Please let me know anything will help. car still runs and drives fine and will still pull if i want it too. I will be doing a compression and blow down test here shortly (If there is a how to about disabling ignition let me know so i can run these tests) Thanks for stopping by!
tamadrummer
03-08-2016 01:50 PM
SSMiKE8
02-25-2016 07:07 PM
