Help!!! Car has no power
Headed to work this morning my car just had a loss of power and started missing badly. While on the way to autozone eng pwr reduced pops up. And when i get there they come up with a p0068 code can anyone help me with this? BY THE WAY IT'S AN 06 LS 2.2
correlation issues, then you will get a p0068 and p0069 together... To play it safe, grab a good code reader and check the value of your map sensor to your barometric sensor with the key on, engine off. They should be the same. If not your map sensor is bad. If they are the same, clean out your mass air flow sensor, and reset your computer. If it comes back on again, replace mass air flow sensor.
twilson380
09-14-2015 10:52 AM
