HELP! Got a P0140 CEL code
P0140 - 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
This would happen if your o2 sensor was not connected.
Check the wire on the exhaust after the cat con, you will need to get under your car, see if the o2 sensor wire is not disconnected from the sensor, it could be as simple as a unplugged sensor.
OrangeCoba
09-25-2015 06:06 PM
