Help....HHR SS front wheel spins too freely in gear. Too much play? Quick vid inside
57,000 miles.
Tune.and.DP.
Noticed today that it had a.shimmy when engaging clutch.
Drives perfectly fine but I still ran home and lifted it.
The front wheel has more play then I ever imagined a fwd lsd should.
Short vid of me able to spin the wheel before it grabs the gear.
Sooooo what did I break, or is it normal?
Watch "Excess wheel play. FWD" on YouTube
Excess wheel play. FWD:
Tune.and.DP.
I don't really know much but maybe part of what ever gear it's in has broken off and it takes more spin or whatever till it catches a tooth on the gear. Whatever i'm saying. What gear were you in?
I pulled it down into 4th.
It drives perfectly fine.
Someone saw it shimmy on takeoff.
Good point about gear.
They do have some play?
Before I posted I'm hearing
Clutch
Splines
Half shaft
Etc
Clutch
Splines
Half shaft
Etc
well at first I was like wtf. but then my buddies car did the same thing with LSD and I figured it was normal.
Im on the ZFR at 30 psi and my car has 94k miles almost, so I haven't had any issues.
