HELP! Loud grinding metallic scrapping noise!
Old 01-21-2007, 06:54 PM
Mercury's Avatar
Any updates on this? I just started experiencing the same issue after picking up my car from the dealer
Old 01-21-2007, 07:01 PM
Matty's Avatar
What did you have done?
Old 01-21-2007, 07:11 PM
Mercury's Avatar
GM Stage 2 install and had the thermostat replaced
Old 01-21-2007, 07:14 PM
Matty's Avatar
E to the X's was his wheel hitting the skirt.
Maybe they checked your air filter out and now it is the same thing?
Is yours a grinding or squealing?
Old 01-21-2007, 07:16 PM
Coblasts's Avatar
Had The same Problem
I heard some one else had this repaired ,all the dealer did was put another screw in the tab on the ground effect to hold it back.
Going to look into it when the weather warms up.
Old 01-21-2007, 11:56 PM
SoloZ/SS's Avatar
Mine does the same thing, I shaved the top of the skirt where it can come into contact with a die grinder. This fixed it but just the other day it made the noise under braking and turning right at the same time. Mine started making the noise when I had install my snow tires.
Old 03-17-2010, 11:07 AM
pat_07ss's Avatar
same thing happened to mine, thanks to this thread!
I'll fix my lip tonight
biniecki
10-25-2015 02:23 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
jimbofug007
10-02-2015 12:06 PM
DANRICKARD
10-01-2015 12:08 AM
Slick_Nick
09-28-2015 09:15 PM
Quick Reply: HELP! Loud grinding metallic scrapping noise!
