Help me figure out my squeaks!
Hey guys, 07 2.4L LS here...
Everytime i press the break pedal something in the rear of my car squeaks.
Also, what do control arm bushing squeaks sound like? I'm pretty sure I need to change those out as well...
Every time i back out of my driveway my springs "crank" and squeak terribly. Is there any solution to that besides replacing them?
And finally, when i ACCELERATE (yup, thats right!) there is a little squeak when the gear changes, but only every so often. But the squeak is loud as hell. At first i thought it was my interior just being the plasticy POS it is, but after opening my indow its coming from under the hood somewhere.
Well the sqeaking in the rear when depressing the brake pedal while sitting still cam only be from the brake calipers centeralizing which means the pins need to need to be lubed or the contact area the pads ride on(the anti squeal shims)may need a little lube.
Delta coupe
09-30-2015 08:11 AM
