Help, my car won't reset O2 and Evap after throwing code & won't pass emissions
Old 12-13-2012 | 07:41 PM
DM725's Avatar
Help, my car won't reset O2 and Evap after throwing code & won't pass emissions. My car has been driven 1,500 - 2,000 miles since I cleared the code. My car is tuned and the tuner has since deleted all of the emissions related lights but it didn't help.
Please help.
Old 12-14-2012 | 01:52 AM
insylem's Avatar
Please help.
Um fix the problem?
Old 12-14-2012 | 11:31 AM
Hockeyman's Avatar
find a shady place and pay them off to pass the car
Old 12-14-2012 | 01:29 PM
MyOtherSS's Avatar
I think the tc takes forever to set the evap and or o2. There is certain criteria you need to meet for it to run the test, it's been posted in here before ill try and find it later.
Old 12-15-2012 | 12:18 AM
DM725's Avatar
Originally Posted by insylem
Um fix the problem?
Ok how?
Old 12-15-2012 | 10:52 AM
DM725's Avatar
THANKS, could it be a bad O2 sensor?
Old 12-16-2012 | 01:39 PM
MyOtherSS's Avatar
Not sure what codes you were throwing but check out this thread. Also I would recommend not clearing codes and just driving it because you are just starting from scratch every time you do. It took me 2 weeks in my lsj to get the Evap to set. OBD II Readines Monitor "trick"? - HP Tuners Bulletin Board
Old 12-16-2012 | 04:36 PM
efren6057's Avatar
^^^ This
Old 12-18-2012 | 05:00 AM
scagnetti76's Avatar
simply erasing codes will not help passing emissions. any kind of info regarding exhaust gasses coming out the tail pipe to help? CO, Co2, HC, o2 and NoX being the ones concerned. You are probably rich being tuned. But from the info you gave, nobody can say "this is your problem.''
Old 12-18-2012 | 07:54 PM
DM725's Avatar
Yea I haven't thrown a code in months. I got a CEL, checked it, cleared it, and it never presented itself again. Then I drove it for roughly 1,000 miles and my mechanic is telling me my 02 and Evap aren't reset.
It's not like i'm throwing codes every day and deleting them trying to get my car to pass emissions.
Old 12-18-2012 | 08:06 PM
DM725's Avatar
Thank you for the link, I'll see if my tuner can help me since I wouldn't know how to do any of that.
Old 12-18-2012 | 10:25 PM
LS6Rally's Avatar
some systems will not check without the other, im not sure if eva and o2 are one of them. is it your Catalyst Monitor that will not go ready? what are you running for a cat? do you haev the rear O2 turned off through HPT because you are catless or are running a High-flow?
Old 12-22-2012 | 03:25 PM
BlueDemon's Avatar
Well I had the same problem, but it only took my evap system 4 days to be "ready". You made sure all your fuses are ok and your coolant and everythings good?? Little things could cause your computer to not set it.
Old 11-06-2018 | 02:34 PM
Sharkey's Avatar
thanks guys.
i forgot to mention that battle everything once they announce the top 12 was filmed for a tv special on velocity/discover/motor trend. it will air sometime near the beginning of february. once i find out the date ill let you know.
Cobalt08LS
09-12-2012 08:55 AM
Blowncavy
05-24-2012 10:45 PM
395 plus
05-20-2011 06:51 PM
2006RedCobaltSS
05-18-2010 11:30 PM
RedEcotecSS
01-24-2008 02:08 PM
Quick Reply: Help, my car won't reset O2 and Evap after throwing code & won't pass emissions
