Help no start
Old 07-24-2016 | 12:28 PM
Nick07Ss's Avatar
Help no start
Hey guys having an issue. Everything was fine until I came out of work the other day. Had no start no crank starter is just clicking. Tried boosting it same thing, bumped it drove it to my parents pulled the starter off and tested it and it engaged and spun put everything back together and same issue. Had code p0365. Any ideas?
Old 07-24-2016 | 04:45 PM
umrdyldo's Avatar
Check the crank position sensor. Either bad or come unplugged
Old 07-24-2016 | 07:12 PM
Sharkey's Avatar
Originally Posted by umrdyldo
Check the crank position sensor. Either ad or come unplugged
wut?
p0365 is camshaft position sensor intermitent signal. to fix that id start with checking and cleaning the connection, clear the code and if it comes back put a new sensor in. but this has nothing to do with a no crank no start.
you need to find out if the starter is clicking, or if the starter relay in the fuse box your hearing. if the solenoid is clicking id check grounds and your positive cable connections. also check to see if its actually getting voltage on the start wire at the starter while trying to crank it.
Old 07-27-2016 | 04:30 PM
Nick07Ss's Avatar
So there is power at the starter and when I try and crank it there is 0.25 v on the signal wire and zero when it's in run. Could it be the ignition switch?
Old 07-27-2016 | 07:17 PM
Nick07Ss's Avatar
Update . Changed the power wire from the fuse box to the starter checked the grounds all seems fine has power to the starter until you go to crank it the the voltage drops to zero... I'm baffled
Old 07-27-2016 | 07:35 PM
T-fog's Avatar
^This
I know it doesn't seem related, But i recall a thread about someone having a no start and it was telling them to check the cam sensor and it ended up being a bad crank sensor.
Sorry this post isn't much help, But if your at a dead end it wouldn't hurt to check the sensor and its wiring to rule that out as the culprit.
Old 07-27-2016 | 07:50 PM
Nick07Ss's Avatar
What am I looking for with the crank sensor?
Old 07-27-2016 | 08:54 PM
T-fog's Avatar
I stumbled on this with a quick search for you, If you read one of his Q and A he stated that he had a bad or faulty crank sensor but it didn't trigger a code. Also there is links at the bottom maybe some reading will help you determine the issue as well or narrow it down at least.
https://www.cobaltss.net/forums/prob...o-start-54807/
You can inspect the wiring for breaks and/or damage, And also see if all the pins are seated in the connector, Besides that I don't know if you can clean the sensor or if there is a way to test it or anything...Hopefully someone can chime in on that.
Also on a side note if this is your issue, You will need to do the crank relearn procedure. Just a heads up.
Hope this helps and keep us posted
Old 07-28-2016 | 11:09 AM
Nick07Ss's Avatar
Oh its not the crank sensor I can bump start the car I'm now leaning towards the clutch position sensor or a different gremlin because it isn't getting the 12v to the signal wire to engage the starter
Old 08-05-2016 | 10:48 AM
Nick07Ss's Avatar
Bump update I checked all the fuses and the clutch switch all in working order... only thing left is the ignition switch? I'm running out of ideas now
Old 08-05-2016 | 03:15 PM
umrdyldo's Avatar
I know you said it's not the crank sensor, but if you still have the P0365 then you should start by replacing the crank sensor.
Old 08-06-2016 | 12:19 AM
Nick07Ss's Avatar
The crank sensor all seemed to be no run issues not start I can bump start the car and drive it np and the code is gone which is why im thinking its the ignition
Doug's Cobalt SS SC
05-24-2016 05:09 PM
Doug's Cobalt SS SC
05-15-2016 10:36 PM
tomj77
05-14-2016 01:37 AM
double clutch
05-11-2016 05:19 PM
joeyfingers
05-02-2016 02:58 PM
