help with relay harness and hids
right. i have the power and ground ring connectors and then i have the 2 connectors that connect to the ballasts and then 2 male pin connectors and then the bulbs have male pin connectors too
#36
The relay harness has 2 plugs. THey go into the ballasts. The plugs from the bulbs that look the same from the relay harness are not used because your getting power directly from the harness now and not the stock wiring. it SEEMs confusing but when you slow down and check it out its very simple. Also each plug from the relay has a wire that needs to be grounded. Make sure the plugs are not backwards on the ballasts. they should go over the small slanted bump and not the huge one.
