help with relay harness and hids
Old 09-15-2010, 11:07 PM
hook's Avatar
my relay
clips on relay?
one hole
two plugs and factory plug looks like this
Old 09-15-2010, 11:27 PM
SS_NH's Avatar
did you get dustins out to look at? lol.
looks like his is wrong too then, but i was crazy when i tried to say it wasnt right.
Old 12-16-2010, 11:58 PM
rekameohs_nire's Avatar
i know this is a from the dead bumb but i just got my hids with a relay and mine look the same and im very confused?
Old 12-17-2010, 07:25 AM
Old 12-17-2010, 12:09 PM
Old 12-17-2010, 12:15 PM
umrdyldo's Avatar
Here is the main install with photos
https://www.cobaltss.net/forums/how-...arness-204719/
Did you message BuyHID.com yet?
Old 12-17-2010, 01:17 PM
like a few have said in this thread i have pin connectors that the how to doesnt show
Old 12-17-2010, 02:00 PM
Old 12-17-2010, 02:02 PM
umrdyldo's Avatar
and they aren't the normal power and ground connectors right?
I see how they aren't in the other pictures.
Old 12-17-2010, 02:13 PM
right. i have the power and ground ring connectors and then i have the 2 connectors that connect to the ballasts and then 2 male pin connectors and then the bulbs have male pin connectors too
Old 12-18-2010, 09:50 AM
  #36
mkulrey13's Avatar
The relay harness has 2 plugs. THey go into the ballasts. The plugs from the bulbs that look the same from the relay harness are not used because your getting power directly from the harness now and not the stock wiring. it SEEMs confusing but when you slow down and check it out its very simple. Also each plug from the relay has a wire that needs to be grounded. Make sure the plugs are not backwards on the ballasts. they should go over the small slanted bump and not the huge one.
ineedacobaltss
11-07-2015 02:25 PM
chefhhr
10-26-2015 10:36 PM
dennis69
10-20-2015 07:39 AM
dieGone
09-23-2015 10:20 AM
Jeffwills14
09-06-2015 06:52 PM
Quick Reply: help with relay harness and hids
