High IAT2 on friends TVS
Old 05-13-2016 | 04:38 AM
xRedrumisBack's Avatar
My friend has a TVS stock pulley and the IAT2s climb much faster than my m62 wth a 2.7in pulley.
We both have identical cooling mods: Option B, DualPass, ZZP H/E.
During a 2-3 pull my IAT2s usually go from 105-125. His will go from 105-130, and then heat up to 135 after letting off gas.
I did the install for the dual-pass and option B on both cars, both are bleeding correctly.
His TVS setup makes about 20-21psi and my m62 2.7 setup makes 15-16psi. My exhaust flows better.
Old 05-13-2016 | 07:41 AM
Staged07SS's Avatar
Administrator
Administrator
If u think they are bled correctly... check is intercooler pump.
My money is on a bad pump or trapped air.
Give the pump a tap with a rubber mallet and feel the lines for moving coolant.
Old 05-13-2016 | 10:15 AM
ItalianJoe1's Avatar
135 is bad after a 20psi pull? In what world?
Old 05-13-2016 | 11:28 AM
Staged07SS's Avatar
Administrator
Administrator
Very true.. .good catch. I forgot this is a TVS vs a M62.
Although the TVS is more efficient, it's moving more air than that 2.7 M62.
Old 05-13-2016 | 12:28 PM
advise's Avatar
thats nothing ive had 170 with similar cooling mods and pulley
sounds like the motor is stock with minimal exhaust
Old 05-13-2016 | 06:35 PM
Psykostevo's Avatar
LOL, 135* is IAT2 at idle in Arizona!
Old 05-14-2016 | 12:45 AM
Exactly, when I see IAT2 below 140 i'm super happy, i'm not even talking about WOT pulls. I only get worried when I see 170+, that usually means the pump is out and it will go over 200 on a pull if so.
Old 05-14-2016 | 02:36 PM
That's what I was thinking, just read so many posts about people saying the TVS is "way cooler", my car is also a ion redline, it's possible that could make a difference on airflow over the stock HE since there's more room in front of it.
His TVS is on 93, and timing hates high IAT2s on his car.
Cman46290
07-01-2016 08:56 AM
QuickSilver_SS
05-02-2016 08:41 PM
ccsssc
04-30-2016 02:09 PM
Stumpalump
04-25-2016 07:40 AM
Stumpy
04-18-2016 04:51 PM
Quick Reply: High IAT2 on friends TVS
