High pressure in clutch pedal during 3-4 shift
The dampener is seen from the top. Look behind the fuse box next to the strut tower. You move have to push a wire harness to the side but you can see it if it's there. You can see where the line connects to the master and it's right off of the master of you have it.
If you have it hit up Josh and get the OTTP stainless steel clutch line. I have it. You can't just remove it as you will need a longer line to reach without it. Josh's line is long enough to use it or delete it.
I really don't think I have it though.
Well... not sure if it was the problem or not, but my issue is gone.
I removed my zzp fuel pump rewire. The clutch issue started after I installed it (oddly enough). Never felt comfortable with this mod anyways.
I also changed my trans fluid (fluid was dark red). Shifts a little smoother, nothing to write home about though.
All in all, I was very happy with the 1-3 into 4th pulls yesterday.
Alex S
41
03-18-2016 03:20 PM
