High RPM After Cleaning Throttle Body
#76
I cleared mine already, I also disconected my batery for a hr and its still the same. I just dropped it off at my local performance shop tonight, and he said the same thing majourpain said, that the sensors were thrown off so it defaults to the warm up idle.
When I get my car back tomorow I'll let you know what he comes up with.
#77
If you used WD 40 to clean the TB then it has most likely coated the TPS and MAP sensors. Remember that whatever you squirt into the TB will hit the SC, intake manifold and straight into the motor. Cleaning the TB does not require you to remove the unit itself! Squirting TB cleaner into the intake is sufficient and removing the TB only increases the chances of you ruining the TB by moving the plate. I did it 3 times with my 05 SC and never once had a problem.
#79
i'm gonna try a TAC module update tonight and i will let you guys know how it goes.
nope, didn't give me the option to do a TAC update. and i've already got the latest ECM update. sorry guys
#80
#81
out of curiousity how many of us are using CAI or SRI and having this issue and how many of us still have the stock intake and are having this issue. its something that hasn't really been asked. off had i'm using a CAI and i can't remember if it did this when i had my stock intake on. and i'm too lazy to put the stock one back on to find out if its the cause.
#82
#87
Yep, correct me if Im wrong but i think this is what they stand for.
PCM- Powertrain Control Module
ECM- Engine Control Management
Its close I know LOL.
But yes, the computer will need to restored to its defualt state so it will relearn the new air/fuel ratio values instead of compensating for the crud in the TB and increasing idle.
#88
my mechanic is telling me that the sensors in my throttle body are toast because they are sensitive to carb cleaner. He hooked a meter to the sensors, and he said the readings were speratic. Also when he put it to full throttle the blade only opened half, but the computer still read %100 throttle.... so I dont know what that means, but he told me I need a new tb.
Does any of that make sence to you guys?
#89
its possible that thats just a random thing. my driveability techs at work have been using carb cleaner to clean throttle bodies for years with no ill effects. but its definetly something to look into. i'll ask my guys tomorrow and see what they say.
#91
Yep I proved the idiot wrong. It just needed to be reflashed to reset the TPS. I hate stubborn fools.
#93
My mechanic charged me $500 for a new manifold and gaskets. That had nothing to do with the problem. I had to MAKE him reflash my ECU. Im 17, and he said that Im just a kid and hes the mechanic..
#94
Cold starts, stuttering and stalling. BAD.
Clean throttle body with TB cleaner on micro fiber rag. GOOD.
Fix problem. GOOD.
Computer had to be reset so it would stop opening the throttle body more to compensate for carbon deposits. BAD.
Stupid mechanic who wouldnt listen to me. BAD.
He finally listend to me. GOOD.
Good boy.
#95
#97
if your referring to the tire pressure monitors, having a relearn done for that and this issue are 2 totally differen't things. and no i didn't. i've got a buddy with a 2.4 that doesn't do this, so him and me are gonna swap throttle bodies and see if his does it or not before i do the reflash. if his starts doing it and mine stops then i know its the throttle body or one of its components that are failing. if everything is still the same then i will continue on with the reflash
#98
I can save you the work of swapping throttle bodies. My shop just put a brand new one in today, and its still acting up
They're going to do a reflash tomorow to see if anything changes.
#100
